Installing OF1.6 from git
Old   December 12, 2009, 19:49
Question Installing OF1.6 from git
Eric Nutsch
ericnutsch is on a distinguished road
Send a message via Skype™ to ericnutsch
With assistance i have successfully compiled OpenFOAM1.6 from source on ubuntu 9.10 with the system compiler(not OF supplied). Now I am now trying to compile the most recent git version.
Here is the process(i think):
1. Download the git version to the OF directory
http://www.opencfd.co.uk/openfoam/download.html
(does the git version need the downloaded source packs in addition or is this git folder all that is needed??)
2. Let the system know where it is at:
export FOAM_INST_DIR=/home/eric/OpenFOAM.gcc
source etc/bashrc
3. Change compiler to system compiler(optional)
gedit etc/settings.sh
4. Compile
./Allwmake
Initially I got an error where the compiler couldnt find ThirdParty-1.6.x
I fixed this (maybe) by creating a link to my source pack folder
ln -s ~/OpenFOAM/ThirdParty-1.6 ~/OpenFOAM/ThirdParty-1.6.x
The new error says:
CMake Error: your CXX compiler: "/bin/c++" was not found.
Please set CMAKE_CXX_COMPILER to a valid compiler path or name.
-- Configuring incomplete, errors occurred!
I looked and sure enough "/bin/c++", but "/usr/bin/c++" did.
so i used the code:
export CMAKE_CXX_COMPILER=/usr/bin/c++
source etc/bashrc
But it didnt have any effect on the error outputs of ./Allwmake
Thoughts? Any help is greatly appreciated!
I have reviewed the following related forums:
http://www.cfd-online.com/Forums/ope...ion-1-6-a.html
http://www.cfd-online.com/Forums/ope...-cookbook.html
ericnutsch is offline   Reply With Quote
Old   December 13, 2009, 19:00
Eric Nutsch
I figured out that through about 4 links "/usr/bin/c++" eventualy points to " /usr/bin/g++-4.4"
Maybe i should point the compiler somewhere else...
git problem with http repository az_monger OpenFOAM Bugs 2 September 4, 2009 05:45
git svn clone of openfoam-extend Bost OpenFOAM 12 August 3, 2009 20:16
Urgent Git problem updating OF15x thomasduerr OpenFOAM Bugs 4 July 8, 2009 07:07
Urgent Git problem updating OF15x thomasduerr OpenFOAM 0 July 7, 2009 11:36
Installation Problem with GIT sega OpenFOAM Installation 2 May 8, 2009 08:46
