fijinx |
December 19, 2009 16:29 |
Bug in path variable $FOAM_RUN
I have installed OpenFOAM 1.6 on Ubuntu 9.10 and moved the install to a different directory. I updated the path variable and everything works except when I went to $FOAM_RUN, it is still trying to go back to where it "should" be installed. I checked my enviornmental variables by typing env in the console and FOAM_RUN, FOAM_USER_APPBIN, WM_PROJECT_USER_DIR are all point to the wrong directory. The rest are correct. Any help is appreciated.
