January 1, 2010, 09:47 |
OpenFoam1.6 Installation in Ubuntu9.10
Mohanavelu Palaniswamy
I have run the foamInstallationTest, I have got 1 critical error regarding gcc version mismatch . I like to know how to overcome the critical error.
Executing /home/mohanavelu/OpenFOAM/OpenFOAM-1.6/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: mohanavelu-laptop OS: Linux version 2.6.31-16-generic ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/mohanavelu/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/mohanavelu/OpenFOAM/mohanavelu-1.6 no no $WM_THIRD_PARTY_DIR /home/mohanavelu/OpenFOAM/ThirdParty-1.6 yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/mohanavelu/OpenFOAM/OpenFOAM-1.6 yes yes yes $FOAM_APPBIN ...M-1.6/applications/bin/linuxGccDPOpt yes yes yes $FOAM_SITE_APPBIN .../OpenFOAM/site/1.6/bin/linuxGccDPOpt no no $FOAM_USER_APPBIN ...u-1.6/applications/bin/linuxGccDPOpt no no $WM_DIR ...hanavelu/OpenFOAM/OpenFOAM-1.6/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...nFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt yes yes yes $FOAM_SITE_LIBBIN .../OpenFOAM/site/1.6/lib/linuxGccDPOpt no no $FOAM_USER_LIBBIN ...OAM/mohanavelu-1.6/lib/linuxGccDPOpt no no $MPI_ARCH_PATH ...penmpi-1.3.3/platforms/linuxGccDPOpt yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.3 User version : 4.4.1 Minimum required: 4.3.1 gcc 4.4.1 WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.12 /bin/gzip tar 1.22 /bin/tar Aborted icoFoam 1.6 ...AM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/icoFoam ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. |
January 2, 2010, 05:51 |
Tamás Baksa
I am on openSuse 11.2 but have the same problem
I had an other problem described in an other thread here so I set the compilerInstall=System (line 98 in file /.../OpenFOAM-1.6/etc/settings.sh) based on recommendation by grig after that foamInstallationTest gives the error you have so you could try to set compilerInstall=OpenFOAM and try whether foamInstallationTest and any application that uses gcc (kde, gnuplot) can run as well Last edited by tamas.baksa.hu; January 2, 2010 at 05:52. Reason: grammar |
January 2, 2010, 10:58 |
OpenFOAM Installation
Sir, I have made changes as proposed by you in two file
/OpenFOAM-1.6/etc/setting.sh as well as /OpenFOAM-1.6/etc/setting.csh |
openfoam 1.6 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Installation problems | indy | OpenFOAM Installation | 7 | April 3, 2009 09:40 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Problem in installation of OpenFOAM | sachin | OpenFOAM Installation | 7 | January 22, 2008 01:40 |
Installation problems | shellbell1999 | OpenFOAM Installation | 9 | April 6, 2006 13:29 |
