OpenFOAM-1.5-dev SVN 1563 on Fedora 12 (32-bit) - Successful
Old   January 4, 2010, 13:06
Default OpenFOAM-1.5-dev SVN 1563 on Fedora 12 (32-bit) - Successful
Philippose Rajan
philippose will become famous soon enough
Hello everyone,
First and foremost... A Very Happy New Year to you all :-)!
Just wanted to report, that I just completed compiling OpenFOAM-1.5-dev on my laptop running Fedora 12.... specific details of the build are:
** OpenFOAM version: 1.5-dev SVN Ver. 1563
** Operating System: Fedora 12 (32-bit)
** GCC version: 4.4.2
** ParaView version: 3.7.0 (CVS update: 14.12.2009)
** Parallel library: OpenMPI
In order to compile successfully, I had to make the following changes to the source code, which have been mentioned earlier by users compiling OpenFOAM-1.5-dev on recent Ubuntu and Solaris systems with GCC 4.x.x compilers:
1. At line number 43 in the file: <OpenFOAM src>/OpenFOAM/include/OSspecific.H, the following line was added:
#include <stdint.h>
#ifndef OSspecific_H
#define OSspecific_H
#include "fileNameList.H"
#include "long.H"
#include <stdint.h>
#include <sys/types.h>
2. The file: <OpenFOAM src>/meshTools/triSurface/surfaceFeatures.C was modified at line number 769 to add on a dynamic_cast for "samples":
    // Build tree out of all samples.
    octree<octreeDataPoint> ppTree
        treeBoundBox(dynamic_cast<const UList<point>&>(samples)),      // overall search domain
        octreeDataPoint(samples),   // all information needed to do checks
        1,          // min levels
        20.0,       // maximum ratio of cubes v.s. cells
        100.0       // max. duplicity; n/a since no bounding boxes.
A similar occurance at line 870 of the same file was modified in the same manner.
** NOTE #1: Since I use my own compile of Paraview-3.7.0, I had to copy the plugins generated by PV3FoamReader (libPV3FoamReader.so and libPV3FoamReader_SM.so) into the plugins folder of the ParaView-3.7.0 install which is located within the "bin" folder.
** NOTE #2: I typically use Paraview for postprocessing my OpenFOAM simulations with the plugin created by Takuya Oshima, but I always have both plugins (the one from Takuya and the one included with OpenFOAM) in running condition so that I can test both..... Since Takuya's plugin works with the file extension ".foam" and the one in OpenFOAM with ".OpenFOAM", both plugins co-exist happily without any conflicts.
Have a wonderful year 2010....
Philippose
philippose is offline   Reply With Quote
Old   January 5, 2010, 03:03
Gijsbert Wierink
gwierink is on a distinguished road
Excellent!! Thank you, Philippose, I will go and try it soon with F12 64 bit! If there's anything special I'll post it of course. And a happy new year to you too!
Regards, Gijs
gwierink is offline   Reply With Quote
Old   January 7, 2010, 00:44
Philippose Rajan
For the sake of closure on this thread, the latest SVN version of OpenFOAM-1.5-dev: SVN 1570.... has all the source code modifications required to allow for compilation on gcc-4.4.x without having to make any more changes.
For those facing an issue with errors of the nature: "*** missing separator......." refer to the following thread:
http://www.cfd-online.com/Forums/ope...c-4-4-2-a.html
Have a nice day!
Philippose
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 12:13
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 12:12
OpenFOAM 1.5 installation on OpenSUSE 11.0 bigphil OpenFOAM Installation 16 April 29, 2009 06:28
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
