January 6, 2010, 06:05 |
OpenFOAM-1.6 on Suse10
shyam prasad
Rep Power: 17 |
Hi Foamers,
I have installed OF-1.6 64 bit version on Suse 10. The foamInstallationTest is ok, my precompiled solvers like icoFoam works fine, but when I compile say MRFSimpleFoam, I get the following error g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/software/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels -I/software/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/incompressible/RAS/RASModel -I/software/OpenFOAM/OpenFOAM-1.6/src/transportModels -I/software/OpenFOAM/OpenFOAM-1.6/src/transportModels/incompressible/singlePhaseTransportModel -I/software/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/software/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/software/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/MRFSimpleFoam.o -L/software/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt \ -lincompressibleRASModels -lincompressibleTransportModels -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/u530655/OpenFOAM/u530655-1.6/applications/bin/linux64GccDPOpt/MRFSimpleFoam /software/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so: file not recognized: File format not recognized collect2: ld returned 1 exit status I have tried both installation in alternative locations and default location, both the give the same error. Any suggestion will be of great help. Thanks in advance. |
January 7, 2010, 02:37 |
#2 | |
Mark Olesen
Rep Power: 40 |
I'm afraid that the easiest solution is updating your system. |
January 7, 2010, 05:15 |
Simon Rees
Rep Power: 17 |
I have found exactly this problem with our 1.6 installation on our Cluster that uses SLES 10. The only way arround this is to compile OpenFOAM on the machine rather than use the binary distributions. I have been told that this is essentially a bug in SLES 10. We have not found the same problem on our Redhat system and I still do not understand why there was no problem with 1.5 and now there is with 1.6.
Regards, Simon |
install OpenFoam 1.6 by building source: how? | niudie | OpenFOAM Installation | 13 | April 26, 2011 00:48 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
List of glitches found on OpenFOAM 1.6 | wyldckat | OpenFOAM Bugs | 5 | November 17, 2009 07:51 |
OpenFOAM 1.6 package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 36 | September 2, 2009 12:46 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 17:55 |
