OpenFoam installation - Qt difficulties?
Old   January 8, 2010, 06:35
Default OpenFoam installation - Qt difficulties?
grsox is on a distinguished road
I am installing OpenFoam for the first time and when I run paraFoam in the icoFoam/cavity tutorial I get:
$WM_THIRD_PARTY_DIR/paraview-3.6.1/platforms/linux64Gcc/bin/paraview-real: symbol lookup error: $WM_THIRD_PARTY_DIR/paraview-3.6.1/platforms/linux64Gcc/bin/libpqWidgets.so: undefined symbol: _ZN11QHeaderView5resetEv
I have downloaded and unpacked qt 4.3.5 into the Third Party directory. The provided makeQt build script was used to put it together.
Paraview was then made with
./makeParaView -qmake $WM_THIRD_PARTY_DIR/qt-x11-opensource-src-4.3.5/bin/qmake
PV3FoamReader is then built as described in the README.
If I ldd several libs in $WM_THIRD_PARTY_DIR/paraview-3.6.1/platforms/linux64Gcc/bin I get several libs not found. For instance ldd libKWCommon.so returns:
libvtkCommon.so.pv3.6 => not found
libvtksys.so.pv3.6 => not found
libpthread.so.0 => /lib64/libpthread.so.0 (0x00002aaaaaced000)
libdl.so.2 => /lib64/libdl.so.2 (0x00002aaaaaf07000)
libstdc++.so.6 => /home/grsox/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6 (0x00002aaaab10b000)
libm.so.6 => /lib64/libm.so.6 (0x00002aaaab418000)
libgcc_s.so.1 => /home/grsox/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libgcc_s.so.1 (0x00002aaaab69b000)
libc.so.6 => /lib64/libc.so.6 (0x00002aaaab8b3000)
Any idea what I am missing?
grsox is offline   Reply With Quote
Old   January 10, 2010, 13:25
Eerin
eros is on a distinguished road
I put LD_LIBRARY_PATH in foam..etc/bashrc contain path to qt libs.
And compiled parawiev plugin too (with compiled qt qmake path)
Parawiev starts, but stucs immediatly, consumes 99% cpu but nothing happens.
32bit machine, ubuntu dapper
That may help in your unresolved symbol broblem, but don't solve my broblem..
Eerin
eros is offline   Reply With Quote
Old   January 10, 2010, 16:51
Eerin
Paraview freeze problem seems to be graphic card problem. It freeze in matrox G550 machine, but when ssh -X from other machine and run same cavity example it works (but aufull slow). Other machine have nvidia quadro card.
Is there somewhere list of working cards with paraview?
Eerin
Old   February 23, 2010, 15:10
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
For your info, I solved the "_ZN11QHeaderView5resetEv" problem by setting LD_LIBRARY_PATH to the lib directory of qt.
louisgag is offline   Reply With Quote
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 14:06
OpenFOAM 1.5 installation on OpenSUSE 11.0 bigphil OpenFOAM Installation 16 April 29, 2009 06:28
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
