Suse10 FoamX problem
Old   September 27, 2005, 05:54
Default Hello and sorry about this lon
Frank Steinbacher
frank178 is on a distinguished road
Hello and sorry about this long message!
I'm totally new in using OpenFoam. :-)
I installed Openfoam 1.2 and the installation test passes without any faults, the icoFoam tutorial also runs without any problems:
sleur@Wb:~/OpenFOAM/frank/run/tutorials/icoFoam> ./Allrun
Running blockMesh on cavity
Running icoFoam on cavity
Cloning cavityFine case from cavity
Running blockMesh on cavityFine
Running mapFields from cavity to cavityFine
Running icoFoam on cavityFine
Running blockMesh on cavityGrade
Running mapFields from cavityFine to cavityGrade
Running icoFoam on cavityGrade
Cloning cavityHighRe case from cavity
Setting cavityHighRe to generate a secondary vortex
Copying cavity/0* directory to cavityHighRe
Running blockMesh on cavityHighRe
Running icoFoam on cavityHighRe
Running blockMesh on cavityClipped
Running mapFields from cavity to cavityClipped
Running icoFoam on cavityClipped
fluentMeshToFoam: converting mesh elbow/elbow.msh
Running icoFoam on elbow
Running foamMeshToFluent on elbow
Running foamDataToFluent on elbow
But when I want to start FoamX:
sleur@Wb:~/OpenFOAM/OpenFOAM-1.2/bin> FoamX
Starting NameServer with inet:Wb:1234 ...
/home/sleur/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: line 122: nsd: command not found
By searching the board, I allready found the hint to change e.g. my port number in $FOAMX_USER_CONFIG/FoamXClient.cfg
but this files and even the directory don't exist.
Can you please help me or give me an hint!! :-)
Thanks!
PS: When I run icoFoam I get following message.
sleur@Wb:~/OpenFOAM/OpenFOAM-1.2/bin> icoFoam
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.2 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : icoFoam
Date : Sep 27 2005
Time : 11:26:40
Host : Wb
PID : 16872
Usage: icoFoam <root> <case> [-parallel]
--> FOAM FATAL ERROR : Wrong number of arguments, expected 2 found 0
FOAM exiting
My foamInstallationTest:
Executing /home/sleur/OpenFOAM/OpenFOAM-1.2/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: Wb
OS: Linux version 2.6.13-9-smp
User: sleur
User_config: /home/sleur/.bashrc
Foam_config: /home/sleur/.OpenFOAM-1.2/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/sleur/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/sleur/OpenFOAM/sleur-1.2 yes no
$FOAM_JOB_DIR /home/sleur/OpenFOAM/jobControl yes yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/sleur/OpenFOAM/OpenFOAM-1.2 yes yes yes
$FOAM_USER_APPBIN ...ur-1.2/applications/bin/linuxGcc4Opt yes yes no
$FOAM_APPBIN ...AM-1.2/applications/bin/linuxGcc4Opt yes yes yes
$WM_DIR /home/sleur/OpenFOAM/OpenFOAM-1.2/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH /home/sleur/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH ...c/mico-2.3.11/platforms/linuxGcc4Opt yes yes yes
$LAM_ARCH_PATH ...src/lam-7.1.1/platforms/linuxGcc4Opt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...enFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt yes yes yes
$FOAM_USER_LIBBIN .../OpenFOAM/sleur-1.2/lib/linuxGcc4Opt yes yes no
Software versions
Software Version Location
gcc 4.0.1 /home/sleur/OpenFOAM/linux/gcc-4.0.1-64/bin/gcc
java 1.4.2_05 /home/sleur/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
gzip 1.3.5 /usr/bin/gzip
tar 1.3.5 /bin/tar
icoFoam ...OAM/OpenFOAM-1.2/applications/bin/linuxGcc4Opt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_Wb Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
Critical systems ok.
frank178 is offline   Reply With Quote
Old   September 27, 2005, 13:50
Default > nsd: command not found C
Mattijs Janssens
mattijs is on a distinguished road
Check whether you have nsd and whether you can execute it. (should be inside $FOAM_SRC/mico-xxx)
Check all arguments to nsd in runFoamXHB script that they are set correctly.
mattijs is offline   Reply With Quote
Old   January 9, 2006, 08:30
Default Hi, I have this nsd-problem on
laika
Hi, I have this nsd-problem on my new AMD6 machine.
Installation went OK.
In the mico-xxx I don't have nsd :-(
How is this possible?
and more important: What to do next?
thanks in advance for any help,
Joeri
Old   January 9, 2006, 09:26
Default FoamX works here on my Suse 10
Hrvoje Jasak
FoamX works here on my Suse 10. I suspect your problem is that mico did not build properly.
do:
src
cd $MICO_PATH
rm -rf platforms
make distclean
./configure --prefix=$MICO_ARCH_PATH --disable-shared --without-x
make
and see what the problem is. If it build correctly, do:
make install
and you're in business.
Hrv
Hrvoje Jasak
Old   January 9, 2006, 10:03
Default Thanks for your response! M
laika
Meanwhile, I discovered that I did have nsd, but that the paths were incorrectly set. I removed 'AMD64' from several directory names, and now I can start FoamX without problems. It's probably better to add 'AMD64' in the variable-names that are used to generate the directory-names in the .bashrc-files. It seems to work now. I don't have time to run a test today, but I'll soon find out wheter or not this was the only problem. If not, I'll follow your procedure and eventually I'll rebuild mico.
kind regards,
Joeri
Old   January 10, 2006, 04:32
Default Any paths that need to be adap
Mattijs Janssens
Any paths that need to be adapted in OpenFOAM setup scripts?
Old   January 14, 2010, 04:18
Default Cavityfine
Begoņa
bego is on a distinguished road
I have another problem, and not to me mapFields cavity in the case of the tutorial. I think the error is that targe mesh size is 1600 and not 1681 as it should. I did everything that I commanded the tutorial, copy the folder in cavityFine cavity blockMeshDict put measures in (40 40 1). Then I put startTime endTime 0.5 and put 1, also did testing with 0.5. In the case of cavity does not change anything. Agadezco to help me as quickly as possible, thanks.
GREETINGS
bego is offline   Reply With Quote
Problem about FoamX williamscn OpenFOAM Installation 8 September 17, 2007 23:18
FoamX problem richardhsieh OpenFOAM Installation 4 September 17, 2007 22:41
Problem running FoamX ianz8802 OpenFOAM Installation 11 March 23, 2007 11:22
StarCD326 SuSE10.0_x86_64 LAM (rsh problem) Mikhail Siemens 1 November 14, 2006 16:37
FoamX problem joegi OpenFOAM Installation 8 November 5, 2006 06:06
