Home > Forums > OpenFOAM Installation
Installation of OpenFOAM 1.5-dev and its fitness for FSI?
Old   March 11, 2010, 08:35
Herman
enry is on a distinguished road
compile with the following instruction:
./Allwmake >&log
Open the log file and see if there is some errors. I think that you don't have some packages.
Regards.
Enry.
enry is offline   Reply With Quote
Old   March 12, 2010, 05:41
Default OpenFOAM-1.5-dev compilation errors
  #22
Aldo Iannetti
aldo.iannetti is on a distinguished road
Dear OF users,
I'm trying to compile OF-1.5-dev on my ubuntu 8.10. The link (OpenFOAM 1.5 dev)supplied by Enry has been useful but I need your last help to study the compilation's log. Now compilation of both Third Party and OF1.5-dev has been carried out but the foamInstallationTest outputs:
Checking basic setup...
Shell: bash
Host: aldo-laptop
OS: Linux version 2.6.27-16-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/aldo/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/aldo/OpenFOAM/aldo-1.5-dev yes no
$WM_THIRD_PARTY_DIR /home/aldo/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/aldo/OpenFOAM/OpenFOAM-1.5-dev yes yes yes
$FOAM_APPBIN ...dev/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_USER_APPBIN ...dev/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR ...aldo/OpenFOAM/OpenFOAM-1.5-dev/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OpenFOAM-1.5-dev/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...OAM/aldo-1.5-dev/lib/linux64GccDPOpt yes yes no
$MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.1
User version : ../src/configure
4.3.2
Minimum required: 4.2.0
gcc ...figure
WARNING: Conflicting installations:
OpenFOAM settings : /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.12 /bin/gzip
tar 1.20 /bin/tar
icoFoam 1.5-dev ...nFOAM-1.5-dev/applications/bin/linux64GccDPOpt/icoFoam
Checking networking...
Action Result Crit
Pinging_aldo-laptop Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
Trying a tutorial I had no problems but I'm afraid I will have in compiling applications (I read a gcc conflict problem)
Here attached my log...can someone have a look. Can you please help me to fix foaminsatllationtest problem?
Thanks
aldo.iannetti is offline   Reply With Quote
Old   March 12, 2010, 11:50
Herman
Go to .../OpenFOAM-1.5-dev/etc/settings.sh and find :
# Select compiler installation
Try to replace the following line into /OpenFOAM-1.5-dev/etc/settings.sh
# compilerInstall = OpenFOAM | System
compilerInstall=OpenFOAM
# compilerInstall=System
instead of
# compilerInstall=OpenFOAM
I had your own problem and I solved It in this way. Somebody says to replace with
but It doesn't work on my computer.
Good luck!
Old   November 16, 2010, 03:18
Default error compiling OpenFOAM
  #24
Paul Reichl
preichl is on a distinguished road
Hi All,
I am having an issue compiling the source code as per the procedure given in InstallOF-1.5-dev.sh Thanks for this (I had to change it slightly as the ThirdParty files were downloaded as a file called "download" instead of "ThirdParty.General.gtgz").
After that everything worked well and most of the compilation works except that I see errors late in the compilation stage related to a missing -lOpenFOAM library.
After searching through the log the first error that I get is (snippet from log file)
+ wmake libso OpenFOAM
linux64GccDPOpt/options:14: *** missing separator. Stop.
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created
I then get a number of errors (much later) as follows
/usr/bin/ld: cannot find -lOpenFOAM
I suspect the later errors are all related to the first one.
Does anyone have ideas for what I should try to get around this?
I have *not* tried using the line below yet but I will try this next.
For the record my ~/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/Make/options file is listed below. I am not sure what if anything is wrong with it.
EXE_INC = \
-I$(WM_THIRD_PARTY_DIR)/zlib-1.2.3
LIB_LIBS = \
$(FOAM_LIBBIN)/libOSspecific.o \
-L$(FOAM_LIBBIN)/dummy -lPstream \
-lz
// Special rule for global/global.Cver:
// We force the recompilation so the revision number will always be up-to-date
$(OBJECTS_DIR)/global.o: FORCE
FORCE:
Thanks in advance for any suggestions,
Paul.
preichl is offline   Reply With Quote
Old   November 16, 2010, 18:39
Paul Reichl
I think that I have solved this problem.
All I needed to do was add a carriage return at the end of the last line so that the file was now 14 lines instead of 13 lines. (i.e. I just edited the file and hit return on the last line)
Hope this helps anyone else who encounters the same problem.
Cheers,
Paul.
Thread Tools
Trackbacks are On
