Rules dirs missing and Allwmake not found
Hi all, i'm trying to install OpenFOAM 1.6 in my ubuntu 9.10, but I fetch the following error when i try to execute ./Allwmake
And if I execute the script 'foamInstallationTest', I get this: Quote:
1st: If you post coding examples and/or shell output, it might be useful to wrap it as code (the '#' editor button) rather than as a quote, which seems to disappear when I replied to your message. This may be a bug in the forum software, I'm not sure.
I have the strong suspicion that sudo will *not* preserve your environment and then the resulting shell does not have any information about your OpenFOAM setttings. Try the following test: Code:
# like you have BTW: Since the intent of sudo is to execute a command as another user (eg, root), it would be quite dangerous if the environment were actually preserved. For example, Code:
PATH=/danger:$PATH |
