Paraview and Qt installation
Old   February 1, 2010, 21:57
Default Paraview and Qt installation
maverick
maverick is on a distinguished road
Hi everbody,
am trying to install open foam 1.6
i have installed open foam without installing Qt
after that i have dowloaded Qt 4.3.5 from link given in open foam site
i have kept the Qt in third party directory untarred it and ran ./qmake and the installation was complete.
Now when i run ./makeParaView -qmake /home/xxxx/OpenFOAM/ThirdParty-1.6/qt-x11-opensource-src-4.3.5 (the path where qmake is present) am getting the following error
cannot find qmake either at $QMAKE_PATH or in current $PATH
can somebody guide me on this
thanks
maverick is offline   Reply With Quote
Old   February 2, 2010, 02:28
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Did you try specifying the full path to the qmake executable?
eg,
./makeParaView -qmake /home/xxxx/OpenFOAM/ThirdParty-1.6/qt-x11-opensource-src-4.3.5/qmake
olesen is offline   Reply With Quote
Old   February 2, 2010, 02:35
Gijsbert Wierink
gwierink is on a distinguished road
I guess you need to add qmake to your environment variables, i.e. add
PATH=/home/xxxx/OpenFOAM/ThirdParty-1.6/qt-x11-opensource-src-4.3.5:$PATH
export PATH
to .bashrc in your home directory (assuming you have a bash shell). That is, if the executable qmake actually lives in /home/xxxx/OpenFOAM/ThirdParty-1.6/qt-x11-opensource-src-4.3.5 of course.
Hope this helps.
Regards, Gijs
gwierink is offline   Reply With Quote
Old   February 2, 2010, 04:02
maverick
[/CODE]
i get the following mesage when i add qmake
specified QMAKE_PATH does not exist on this machine
QMAKE_PATH=home/xxxx/OpenFOAM/ThirdParty-1.6/qmake leaving unspecifed
*** Error: cannot find qmake either at $QMAKE_PATH or in current $PATH
Originally Posted by gwierink View Post
export PATH
I have added the code
to .bashrc file in home directory and then updated the envirnmental variables by
. $HOME/.bashrc
still the same problem exists
and qmake directory is available in the qt-x11-opensouce-src-4.3.5 directory
also when i try finding whether Qt is installed by usind qmake --version , its not able to detect the version instead i get the packages list
have i installed Qt
am kinda new to linux , donno wat to do.
thanks both of u for reply
Old   February 2, 2010, 04:29
Mark Olesen
This message has "home/xxxx/ and not "/home/xxxx/", did you forget the slash?
. $HOME/.bashrc
What? A qmake directory is now available? This is getting really confusing.
First make sure you can actually use qmake. According to your information qmake is found somewhere under the qt-x11-opensource-src-4.3.5 directory which is located somewhere on your system, or perhaps it is a qmake directory (presumably with a qmake executable in it).
Make sure you can actually call qmake. For example,
/SOME/PATH/THAT/YOU/KNOW/AND/WE/CANNOT/qmake -v
On my system,
/usr/bin/qmake -v
QMake version 2.01a
Using Qt version 4.5.3 in /usr/lib64
Once you have this, you can either add "/SOME/PATH/THAT/YOU/KNOW/AND/WE/CANNOT" to your path, or use makeParaView with
-qmake /SOME/PATH/THAT/YOU/KNOW/AND/WE/CANNOT/qmake
Old   February 2, 2010, 05:57
Gijsbert Wierink
. $HOME/.bashrc
And (besides having the right path), did you add also
export PATH
after
Regards, Gijs
Old   February 2, 2010, 06:07
Mark Olesen
export PATH
after ...
This shouldn't be required since the PATH is normally exported anyhow, which can be verified by the output of 'export' (without any arguments).
Unless something is really weird on the system, you should see "declare -x PATH=....", which shows that PATH is indeed exported.
Old   February 2, 2010, 06:29
Gijsbert Wierink
Thanks, Mark, didn't know
Regards, Gijs
Old   February 2, 2010, 08:51
maverick
[QUOTE=olesen;244542]This message has "home/xxxx/ and not "/home/xxxx/", did you forget the slash?
I have not forgotten the slash and i have included export PATH
qmake directory is available in home/usr/OpenFOAM/ThirdParty-1.6/qt-x11-opensource-src-4.3.5 directory.it contains lots of files with .o extension.
i went in the qt-x11 directory where qmake is available and when i typed qmake -v, i get this
* qt3-dev-tools ( You will have to enable component called 'main' )
* qt4-qmake ( You will have to enable component called 'main' )
Try : sudo apt-get install <selected package>
qmake: command not found
should i reinstall qt again, how do i uninstall it, will it solve the problem
Old   February 3, 2010, 02:48
Gijsbert Wierink
Well, it is becoming a bit unclear to me now what is going on.
First of all, what linux distribution are you using? This is important because you may need to install different packages on which Qt depends (or at least the compilation of Qt). If I were you, I would start installing Qt from scratch. Just make a folder containing the qt-x11-opensource-src-4.3.5.tar.gz file and untar it. Then, configure it ("./configure"), make it ("make" or "gmake", depending on the system), and install it (as root, "make install" or "gmake install", and log out of root again). And last but not least, put the right path in .bashrc.
Regards, Gijs
Old   February 3, 2010, 08:45
maverick
am using ubuntu 9.10
i will tyr it
thanks a lot
Old   February 3, 2010, 08:47
maverick
iwill try it
thanks a lot
Old   February 3, 2010, 09:14
Gijsbert Wierink
Great, there is a quite extensive "cookbook" discussion for installing OF in Ubuntu in this thread. Have a good one!
Regards, Gijs
Old   February 7, 2010, 07:29
maverick
hi i was able to install paraview
i used the following code
sudo apt-get install qt4
sudo apt-get install libqt4-dev
and then i installed paraview and pv3foamreader in the way given in readme file
thanks both of u for your help
i hope working in openfoam will be a pleasant experience for me
regards
