kiva 4 installation
Dear All,:)
Hello, I am mechanical Engg student @ NUS, Singapore. Recently, our department has purchased kiva4 software from DSTSC, TN,USA. But, unfortunately we are facing problems to install it. Therefore, i am writing to get some help from cfd online. Please, consider me an amateur in this field as my question may seen to be very basic. 1. What is the sequential procedure for installing this kiva software. [or how can one install this software]? 2. Is linux is mandatory for this software? If yes, then which version is most recommended? 3. Is Fortran is a pre-requisite for installing the kiva ? If yes, then which version should we use? 4. Is it possible to install kiva in windows OS ? I think my questions resemble how amateur i am in this matter. That's why i am knocking the door of cfd-online. Please help. If the questions are too many to you, then you can suggest over a period at your convenience. Regards. Fahd |
Hi there,
To start with, it would be important to know which version of KIVA 4 you are using, is it the serial or the parallel version? Second, KIVA 4 is an open source written in Fortran so it means you don't have to install it, you'll have to compile it and run it. hope it helps |
Dear Sir,
Thanks for your suggestion and helps to run the software. I am sorry for being so late. May i ask some question specially pertaining for running example? my email address is g0800400@nus.edu.sg fahdme_buet@yahoo.com Fahd ME,NUS |
yes of course, you can ask, but what might happen is that i'll not know the answer :)
| All times are GMT -4. The time now is 17:59. |
