Errors of compiling OF 1.6 on Fedora 12
Old   April 29, 2010, 09:48
Unhappy Errors of compiling OF 1.6 on Fedora 12
Maolong LIU
maolongliu is on a distinguished road
Hello all,
Compiling is almost done. This is the only error, perhaps somebody is able to help me.
Thxs.
zipUpMesh
/ansys_inc: file not recognized: Is a directory
collect2: ld returned 1 exit status
make[3]: *** [/home/Maolong/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/zipUpMesh] Error 1
make[3]: Leaving directory `/home/Maolong/OpenFOAM/OpenFOAM-1.6/applications/utilities/mesh/manipulation/zipUpMesh'
make[2]: *** [zipUpMesh] Error 2
make[2]: Target `application' not remade because of errors.
make[2]: Leaving directory `/home/Maolong/OpenFOAM/OpenFOAM-1.6/applications/utilities/mesh/manipulation'
make[1]: *** [manipulation] Error 2
make[1]: Target `application' not remade because of errors.
make[1]: Leaving directory `/home/Maolong/OpenFOAM/OpenFOAM-1.6/applications/utilities/mesh'
make: *** [mesh] Error 2
maolongliu is offline   Reply With Quote
Old   April 29, 2010, 18:22
Retired Super Moderator
Bruno Santos
Dear Maolong Liu,
Welcome to the forum. Something is very strange about the output error you got.
Please try the following commands:
cd $FOAM_APP/utilities/mesh/manipulation/zipUpMesh
wclean all
wmake all
If it still outputs the same error:
then edit the file zipUpMesh.dep and see if you can find something that says "ansys_inc". If it does, then it's because you have something defined in the terminal environment that clashes with OpenFOAM's environment! Probably the variable CFLAGS or CPPFLAGS are set; try running this to check if they are set:
echo "CFLAGS=" $CFLAGS
echo "CPPFLAGS=" $CPPFLAGS
If it doesn't simply output:
CFLAGS=
CPPFLAGS=
Then that's what is influencing the result.
The other possibility, is that the the OpenFOAM-1.6.General.tar.gz didn't unpack properly, which is something known to happen once in a while.
Best regards,
Bruno
Old   May 1, 2010, 03:11
Maolong LIU
Thank you wyldckat.
I installed OF1.6.x, and compiled successfully.
I think maybe its some bugs.
But I copy the relative files of OF1.6.x to OF1.6, and compile it again, this error disappeared, but there are some new errors.
So I'll start to use OF1.6.x.
Thank you.
Originally Posted by wyldckat View Post
Dear Maolong Liu,
wclean all
wmake all
CFLAGS=
CPPFLAGS=
Best regards,
Bruno
fedora 12, zipupmesh
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
