installing openfoam1.5 on opensuse 10.3
1. while unzipping the ThirdParty.linux64Gcc.gtgz using
tar xzf ThirdParty.linux64Gcc.gtgz in the terminal, it shows :- gzip: stdin :unexpected end of file tar: Unexpected EOF in archive tar: Unexpected EOF in archive tar: Error is not recoverable: exiting now What is the solution for this and why this problem arises??....please anybody help me since i am very new to this openfoam software 2. EITHER if running bash or ksh (if in doubt type echo $SHELL), source the etc/bashrc file by adding the following line to the end of your $HOME/.bashrc file: . $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc Then update the environment variables by sourcing the $HOME/.bashrc file by typing in the terminal: . $HOME/.bashrc OR if running tcsh or csh, source the etc/cshrc file by adding the following line to the end of your $HOME/.cshrc file: source $HOME/OpenFOAM/OpenFOAM-1.6/etc/cshrc Then update the environment variables by sourcing the $HOME/.cshrc file by typing in the terminal: source $HOME/.cshrc WHERE IS THIS $HOME/.bashrc file??......I MEAN IN $HOME, I HAVE ONLY OpenFOAM directory that is where all files are unpacked. |
Greetings Vivek and welcome to the forum.
md5sum ThirdParty.linux64Gcc.gtgz This way you can verify if the file downloaded properly. If it's the same, then unpack it. Quote:
ls -la $HOME/.bashrc Best regards, Bruno |
