June 2, 2010, 05:55 |
ERROR WHILE USING decomposePar
Vivek Gupta
Rep Power: 15 |
1. while running the cavity case:-
cfd@linux-bw7o:~/OpenFOAM/cfd 1.6/run/tutorials/incompressible/icoFoam/cavity> decomposePar /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-f802ff2d6c5a Exec : decomposePar Date : Jun 02 2010 Time : 11:49:34 Host : linux-bw7o PID : 18354 Case : /home/cfd/OpenFOAM/cfd-1.6/run/tutorials/incompressible/icoFoam/cavity nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Time = 0 cannot open file file: /home/cfd/OpenFOAM/cfd-1.6/run/tutorials/incompressible/icoFoam/cavity/system/decomposeParDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 62. FOAM exiting HOW TO RESOLVE THIS PROBLEM??.... |
June 2, 2010, 18:08 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Vivek,
Best regards, Bruno
Problem with decomposePar tool | vinz | OpenFOAM Pre-Processing | 18 | January 26, 2011 02:17 |
decomposePar doesn't work fine!!! | beteproxima | OpenFOAM | 2 | March 17, 2010 07:54 |
DecomposePar und 6 DOF possible? | tian | OpenFOAM Pre-Processing | 1 | May 29, 2009 07:52 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
DecomposePar and mergePatchPairs | hannes | OpenFOAM Bugs | 4 | June 26, 2007 12:01 |
