ERROR WHILE USING decomposePar
Old   June 2, 2010, 05:55
Default ERROR WHILE USING decomposePar
Vivek Gupta
vivek070176 is on a distinguished road
1. while running the cavity case:-
cfd@linux-bw7o:~/OpenFOAM/cfd 1.6/run/tutorials/incompressible/icoFoam/cavity> decomposePar
| \\ / O peration | Version: 1.6 |
| \\/ M anipulation | |
Build : 1.6-f802ff2d6c5a
Exec : decomposePar
Date : Jun 02 2010
Time : 11:49:34
Host : linux-bw7o
PID : 18354
Case : /home/cfd/OpenFOAM/cfd-1.6/run/tutorials/incompressible/icoFoam/cavity
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Time = 0
cannot open file
file: /home/cfd/OpenFOAM/cfd-1.6/run/tutorials/incompressible/icoFoam/cavity/system/decomposeParDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 62.
FOAM exiting
HOW TO RESOLVE THIS PROBLEM??....
vivek070176 is offline   Reply With Quote
Old   June 2, 2010, 18:08
Retired Super Moderator
Bruno Santos
Greetings Vivek,
Originally Posted by vivek070176 View Post
cannot open file
I assume you are following the user guide. If so, check the damBreak tutorial first for instructions on how to use decomposeParDict and decomposePar: 2.3 Breaking of a dam
Best regards,
Bruno
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 02:17
decomposePar doesn't work fine!!! beteproxima OpenFOAM 2 March 17, 2010 07:54
DecomposePar und 6 DOF possible? tian OpenFOAM Pre-Processing 1 May 29, 2009 07:52
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
DecomposePar and mergePatchPairs hannes OpenFOAM Bugs 4 June 26, 2007 12:01
