Home > Forums > OpenFOAM Installation
NOTE: mpc involed
Old   June 19, 2010, 15:54
Default NOTE: mpc involed
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
The new gcc version 4.5.0 needs another lib called mpc, besides gmp and mpfr.
the current version is 0.8.2
#---------------------------------*- sh -*-------------------------------------
# \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
#  \\    /   O peration     |
#   \\  /    A nd           | Copyright (C) 1991-2009 OpenCFD Ltd.
#    \\/     M anipulation  |
# License
#     This file is part of OpenFOAM.
#     OpenFOAM is free software; you can redistribute it and/or modify it
#     under the terms of the GNU General Public License as published by the
#     Free Software Foundation; either version 2 of the License, or (at your
#     option) any later version.
#     OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
#     ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
#     FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
#     for more details.
#     You should have received a copy of the GNU General Public License
#     along with OpenFOAM; if not, write to the Free Software Foundation,
#     Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
# Script
#     makeGcc
# Description
#     Build script for gmp, mpfr, mpc and gcc-4.?.?
usage() {
    while [ "$#" -ge 1 ]; do echo "$1"; shift; done
    cat<<USAGE
usage: ${0##*/} <gcc-4.?.?> ...
* build gmp, mpfr, mpc and gcc-4.?.?
USAGE
    exit 1
if [ $# -ne 1 ]
then
    usage "gcc version not provided"
fi
# Set the number of cores to build on
WM_NCOMPPROCS=4
if [ -r /proc/cpuinfo ]
then
    WM_NCOMPPROCS=$(egrep "^processor" /proc/cpuinfo | wc -l)
    [ $WM_NCOMPPROCS -le 8 ] || WM_NCOMPPROCS=8
fi
echo "Building on " $WM_NCOMPPROCS " cores"
GMP_DIR=$WM_THIRD_PARTY_DIR/gmp-5.0.1
MPFR_DIR=$WM_THIRD_PARTY_DIR/mpfr-3.0.0
MPC_DIR=$WM_THIRD_PARTY_DIR/mpc-0.8.2
GCC_DIR=$WM_THIRD_PARTY_DIR/$1
GMPROOT=${GMP_DIR}/platforms/$WM_ARCH$WM_COMPILER_ARCH
MPFRROOT=${MPFR_DIR}/platforms/$WM_ARCH$WM_COMPILER_ARCH
MPCROOT=${MPC_DIR}/platforms/$WM_ARCH$WM_COMPILER_ARCH
GCCROOT=${GCC_DIR}/platforms/$WM_ARCH$WM_COMPILER_ARCH
# Bulid GMP
if [ ! -d $GMPROOT ]
then
#        make distclean \
        mkdir $GMP_DIR/build \
     && cd $GMP_DIR/build \
     && ../configure ABI=$ABI --prefix=$GMPROOT \
     && make -j $WM_NCOMPPROCS \
     && make install
    echo "    Finished building gmp."
else
    echo "    gmp already built."
fi
export LD_LIBRARY_PATH="$GMPROOT/lib:$LD_LIBRARY_PATH"
# Build MPFR
if [ ! -d $MPFRROOT ]
then
#        make distclean \
        mkdir $MPFR_DIR/build \
     && cd $MPFR_DIR/build \
     && ../configure ABI=$ABI --prefix=$MPFRROOT --with-gmp=$GMPROOT \
     && make install
    echo "    Finished building mpfr."
else
    echo "    mprf already built."
fi
export LD_LIBRARY_PATH="$MPFRROOT/lib:$LD_LIBRARY_PATH"
# Build MPC
if [ ! -d $MPCROOT ]
then
#        make distclean \
        mkdir $MPC_DIR/build \
     && cd $MPC_DIR/build \
     && ../configure ABI=$ABI --prefix=$MPCROOT \
      --with-gmp=$GMPROOT --with-mpfr=$MPFRROOT \
     && make install
    echo "    Finished building mpc."
else
    echo "    mpc already built."
fi
export LD_LIBRARY_PATH="$MPCROOT/lib:$LD_LIBRARY_PATH"
# Build GCC
if [ ! -d $GCCROOT ]
then
#        make distclean \
        mkdir $GCC_DIR/build \
     && cd $GCC_DIR/build \
     && ../configure --enable-languages=c,c++ --with-pkgversion='OpenFOAM' \
      --enable-__cxa_atexit --enable-libstdcxx-allocator=new \
      --with-system-zlib --prefix=$GCCROOT \
      --with-mpfr=$MPFRROOT --with-gmp=$GMPROOT --with-mpc=$MPCROOT \
     && make install
    echo "    Finished building gcc."
else
    echo "    gcc already built."
fi
# ----------------------------------------------------------------- end-of-file
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Thread Tools
Trackbacks are On
Specifying nonuniform initial condition msyaml OpenFOAM Running, Solving & CFD 65 April 25, 2016 04:23
Elementwise multiplication operator johndeas OpenFOAM Running, Solving & CFD 2 May 14, 2012 09:45
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP 4xF OpenFOAM Bugs 3 October 16, 2009 05:35
Elements that limit the Courant number skabilan OpenFOAM Running, Solving & CFD 9 July 3, 2008 12:07
A stupid question luckyluke OpenFOAM Running, Solving & CFD 14 August 13, 2007 04:25
