Updating 1.7.x from git
Old   August 9, 2010, 03:40
Default Updating 1.7.x from git
bhh
Bjorn H. Hjertager
bhh is on a distinguished road
When I execute the git pull command I get the following:
[user@OpenFOAM OpenFOAM-1.7.x]$ git pull
remote: Counting objects: 182, done.
remote: Compressing objects: 100% (128/128), done.
Indexing 130 objects...
remote: Total 130 (delta 84), reused 0 (delta 0)
100% (130/130) done
Resolving 84 deltas...
100% (84/84) done
39 objects were added to complete this thin pack.
* refs/remotes/origin/master: fast forward to branch 'master' of git://github.com/OpenCFD/OpenFOAM-1.7.x
old..new: 52680f8..b450273
Updating 52680f8..b450273
etc/bashrc: needs update
fatal: Entry 'etc/bashrc' not uptodate. Cannot merge.
I have used git pull many times before but never had any problem. Can anybody tell me what went wrong and what I need to do to get it rigth?
rgds
Bjorn
bhh is offline   Reply With Quote
Old   August 9, 2010, 04:13
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
You've changed your etc/bashrc file. If you type 'git status' when within the OpenFOAM-1.7.x directory structure, you'll see something like:
# On branch master
# Changed but not updated:
#   (use "git add <file>..." to update what will be committed)
#   (use "git checkout -- <file>..." to discard changes in working directory)
#    modified:   ../etc/bashrc
# Untracked files:
#   (use "git add <file>..." to include in what will be committed)
#    ../../cases/RDC/0/U
Before merging/pulling you should make sure that there are no modified files. In other words, your working directory should match your local master. So do
git commit -a -m "<Insert log entry here>"
before
git pull
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   August 9, 2010, 04:36
bhh
Bjorn H. Hjertager
What should I insert as <Insert log entry here>?
Bjorn
Old   August 9, 2010, 04:49
Something helpful to explain what the commit was about. So if the bashrc file was the only one that was changed, maybe "bashrc file updated with change to openfoam path." or something equally descriptive. 'git log' will show you the history complete with these log entries.
Old   August 9, 2010, 05:08
bhh
Bjorn H. Hjertager
Her is what happened when I executed the command:
user@OpenFOAM OpenFOAM-1.7.x]$ git commit -a -m "bashrc file updated"
*** Your name cannot be determined from your system services (gecos).
Run
git config user.email "you@email.com"
git config user.name "Your Name"
To set the identity in this repository.
Add --global to set your account's default
fatal: empty ident <user@OpenFOAM.(none)> not allowed
Old   August 9, 2010, 05:12
Do:
git config --global user.name "<yourname>"
git config --global user.email "<youremail>"
I think this will set up a .gitconfig file in your userspace.
Old   August 9, 2010, 05:31
bhh
Bjorn H. Hjertager
Thanks!
It works.
rgds
Bjorn
OpenFOAM 1.7.x git problem olauer OpenFOAM Installation 18 July 29, 2010 06:36
git problem with http repository az_monger OpenFOAM Bugs 2 September 4, 2009 05:45
Urgent Git problem updating OF15x thomasduerr OpenFOAM Bugs 4 July 8, 2009 07:07
Urgent Git problem updating OF15x thomasduerr OpenFOAM 0 July 7, 2009 11:36
Installation Problem with GIT sega OpenFOAM Installation 2 May 8, 2009 08:46
