June 30, 2010, 08:42 |
OpenFoam 1.7 Installation
Robyn
Rep Power: 15 |
Hello!
I'm currently trying to reinstall OpenFoam using version 1.7.0 on OpenSuse 11.2. There were no problems with version 1.6 until I close the terminal window. The pathways to use for example blockMesh are then no longer there. So I hope that version 1.7.0 will no longer have this problem. However, I'm now having problems sourcing bashrc. After unpacking the files I will go into the $HOME/.bashrc by typing: vi $HOME/.bashrc I added the following line: #export PILOTPORT=/dev/pilot #export PILOTRATE=115200 .$HOME/OpenFOAM/OpenFOAM-1.7.0/etc/bashrc <------ type esc, then :wq to write and quit the editor. From there the installation guide asks you to type .$HOME/.bashrc into the terminal window (within /etc directory). However, when I do this it states the directory does not exist. Any ideas would be appreciated! Cheers Robyn |
June 30, 2010, 09:18 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Robyn and welcome to the forum!
OK, a little explanation: the dot, in this case, at the beginning of the command line does the same thing as the "source" command. When the dot at the beginning of a command line is the command itself, then a space must be put in between the dot and the rest of the command line So, what you should have in your $HOME/.bashrc file (in this case, the dot is part of the file name and that this file should be hidden) is this: Code:
. $HOME/OpenFOAM/OpenFOAM-1.7.0/etc/bashrc Now, you can either start a new terminal or run this command (anywhere, doesn't need to be in the /etc folder): Code:
. $HOME/.bashrc Now, you might ask "what does it mean to source a file?" Well, it means that the file is not to be just executed as a script, but it should be executed as if it were a function that updates your current shell environment! And that's how the OpenFOAM environment gets set-up and ready to go Best regards, Bruno
June 30, 2010, 09:38 |
Robyn
Rep Power: 15 |
Hello Bruno!
Thanks for the words of wisdom and advice. After following you explanation I now find an error for the foamInstallationTest as follows Executing /home/robyn/OpenFOAM/OpenFOAM-1.7.0/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: linux-4ifd OS: Linux version 2.6.31.5-0.1-desktop ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/robyn/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/robyn/OpenFOAM/robyn-1.7.0 no no $WM_THIRD_PARTY_DIR /home/robyn/OpenFOAM/ThirdParty-1.7.0 yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/robyn/OpenFOAM/OpenFOAM-1.7.0 yes yes yes $FOAM_APPBIN ...1.7.0/applications/bin/linuxGccDPOpt no yes $FOAM_SITE_APPBIN ...penFOAM/site/1.7.0/bin/linuxGccDPOpt no no $FOAM_USER_APPBIN ...1.7.0/applications/bin/linuxGccDPOpt no no $WM_DIR .../robyn/OpenFOAM/OpenFOAM-1.7.0/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt no yes $FOAM_SITE_LIBBIN ...penFOAM/site/1.7.0/lib/linuxGccDPOpt no no $FOAM_USER_LIBBIN ...enFOAM/robyn-1.7.0/lib/linuxGccDPOpt no no $MPI_ARCH_PATH ...7.0/platforms/linuxGcc/openmpi-1.4.1 no yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- /home/robyn/OpenFOAM/OpenFOAM-1.7.0/bin/foamInstallationTest: line 258: [: -lt: unary operator expected gcc gzip 1.3.12 /usr/bin/gzip tar 1.21 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/robyn/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linuxGccDPOpt/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. *** The foam installation contains 1 critical error(s) *** Review the output for warning messages and consult *** the installation guide for trouble shooting. |
June 30, 2010, 09:45 |
Bruno Santos
Rep Power: 128 |
Hi Robyn,
Well, OpenFOAM 1.7 only has a prebuilt version for Ubuntu. So I'll have to refer you now to this thread: http://www.cfd-online.com/Forums/ope...-2-11-3-a.html It has links to instructions on how to build OpenFOAM 1.7 in OpenSUSE 11.2 and 11.3 Best regards, Bruno
June 30, 2010, 09:54 |
Robyn
Rep Power: 15 |
Hello Bruno,
Thanks for the link. I think I might be missing a line in my $HOME/.bashrc file as before there was a test true... at the end of the file I forgot that I deleted. Could this potentially be the problem as the wmake step is not found. Regards, Robyn |
June 30, 2010, 10:15 |
Robyn
Rep Power: 15 |
Thanks Bruno, I will work on it and see where it goes.
Do you know where I could still retrieve a copy of OF 1.6 ? As I was beginning to build my own cases and would not like to be stuck in this position for long. Regards, Robyn |
June 30, 2010, 11:20 |
Bruno Santos
Rep Power: 128 |
Hi Robyn,
OpenCFD's repository for OpenFOAM files is this: http://sourceforge.net/projects/foam/files/ You can get from there all OpenFOAM's since 1.1 Best regards, Bruno
Installation how-to's - OpenFOAM 1.7 - openSUSE 11.2 and 11.3 | alberto | OpenFOAM Installation | 24 | August 4, 2010 00:48 |
Critical errors during OpenFoam installation in OpenSuse 11.0 | amscosta | OpenFOAM | 5 | May 1, 2009 14:06 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
