mpirun trouble
Old   July 21, 2010, 06:01
Default mpirun trouble
vaina74 is on a distinguished road
Hi everybody. Yesterday I made a fresh installation of OpenFOAM-1.7 and today I ran a tested case. I had a mpirun problem:
foamJob -p -s simpleFoam
Parallel processing using SYSTEMOPENMPI with 2 processors
Executing: mpirun -np 2 /opt/openfoam170/bin/foamExec simpleFoam -parallel | tee log
Error : bashrc file could not be found for OpenFOAM-
How can I fix it?
My o.s. is Ubuntu 10.04.
vaina74 is offline   Reply With Quote
Old   July 21, 2010, 06:32
Retired Super Moderator
Bruno Santos
Hi Maurizio,
nice catch! That's another bug So feel free to report it
The quickest fix is this:
sudo ln -s openfoam170 /opt/OpenFOAM-1.7.0
Or this one also works:
sudo ln -s /opt/openfoam170 /opt/OpenFOAM-1.7.0
The script foamExec assumes this premise:
Originally Posted by foamExec
# This script should exist in <foamInstall>/OpenFOAM-<VERSION>/bin/
# extract the <foamInstall> and <version> elements
# using a function preserves the command args
In other words, the script does not take into account the folder format that the debian package installs. I.e., the nomenclature openfoam170 isn't compatible with the script's search mechanism! OpenFOAM-1.7.0 on the other hand is compatible
Best regards,
Bruno
PS: I've hit 500 posts with this post
Last edited by wyldckat; July 21, 2010 at 06:33. Reason: Another possibility for symbolic linking...
Old   July 21, 2010, 06:55
Hi, Bruno.
I hoped you were around here :-)
I ran in the terminal your second hint and - I'm not so expert - it means that a folder named OpenFOAM-1.7.0 is created, linking to openfoam170. But something doesn't work and I still have the same output when launching foamJob. Have I to make any trivial thing (I already opened a new terminal), like rebooting the computer or create again a 'run' folder (I already had HOME/OpenFOAM/user-1.7.0/run)?
Thanks for your help.
Old   July 21, 2010, 07:05
Bruno Santos
Hi Maurizio,
Oops, I forgot one thing... You will have to edit your file "~/.bashrc" and change the line:
. /opt/openfoam170/etc/bashrc
To:
. /opt/OpenFOAM-1.7.0/etc/bashrc
I didn't remember the script needs to be executed from the pertinent folder...
As for using the symbolic link: I think it's the best option, since this way when OpenCFD updates the debian package, you'll have your installed version automatically updated too
Best regards,
Bruno
Old   July 21, 2010, 07:26
I edited the ~/.bashrc file and inserted
# OpenFOAM
but it still doesn't work :-(
Old   July 21, 2010, 08:45
Bruno Santos
Ooook... I had to install it and test it for myself. The fixes above apparently are worthless
The fix that worked for me right now was to edit the file /opt/openfoam170/bin/foamJob:
gksu gedit /opt/openfoam170/bin/foamJob
Then go to the end of the file and where you find:
mpirun $mpiopts $APPLICATION $@ -parallel
Remove the "$APPLICATION" part and save and close.
You better report this, because this is on annoying bug I tried to fix the file foamExec, but it never wanted to work
Best regards,
Bruno
Old   July 21, 2010, 09:50
Bruno,
thank you very much for your temporary fix trick. I need OpenFOAM now, I couldn't wait for a definitve solution. I already posted a thread in the OF bugs section of the forum, just a link to this forum.
Thanks again for your quick help. Best regards.
mpirun problems: exited on signal 11 (segmentation fault) vaina74 OpenFOAM Running, Solving & CFD 17 March 30, 2023 12:53
what is wrong with the mpirun parameter -mca ? donno OpenFOAM 7 February 2, 2023 21:12
Problem with mpirun with OpenFOAM jiejie OpenFOAM 3 July 7, 2010 19:30
Naca0012 k-e mpirun gives fpe whereas simpleFoam not Pierpaolo OpenFOAM 1 May 8, 2010 03:08
MPIRUN fails lfbarcelo OpenFOAM 3 March 29, 2010 07:41
