make: Target `application' not remade because of errors.
1 Attachment(s)
Dear Foamers,
i tried to install Of1.7.0 on Ubuntu 10.04. after typing ./Allwmake and after more than 3 hours this message is appeared: Code:
make: Target `application' not remade because of errors. make.log file is attached. Thanks in advance Maysam |
Greetings Maysam,
The problem is related to a missing X11 header file, which leads to only foamToTecplot360 not being built. A list of packages for Ubuntu 10.04 and OpenFOAM 1.7 is available here: http://www.cfd-online.com/Forums/ope...tml#post268828 If you use the command line given at that post, and then run Allwmake again, you should no longer have any problems :) Now, I will answer to your other thread shortly... Best regards, Bruno |
foamToTecplot360 problem is solved by your guides.
Thank you very much |
1 Attachment(s)
Dear Bruno,
I am new to linux and I am trying to install OpenFOAM1.7.1 on RedHat 5.5. With the foamInstallationTest no error is detected, but when I execute ./Allwmake , I have this error: make: Target `application' not remade because of errors. I attached also the make.log file. Can you help me, please? Thanks in advance Sale |
Greetings Sale,
Mmm, this is a bit odd... OK, there are three possibilities that I can image about this problem:
Dear Bruno,
thank you for your reply, but no of your suggestions worked. However I tried CentFOAM and it works!:) Now I am trying to instal ParaView, so I downloaded qt-x11-opensource-src-4.3.5.tar.bz2 , I unpacked it with: tar -xjf qt-x11-opensource-src-4.3.5.tar.bz2 then I run: ./makeQt but the answer is: bash: ./makeQt: No such file or directory What's the problem? Thanks in advance! Sale |
Hi Sale,
If CentFOAM is working, then you should also be able to install ParaView that comes with it as well! Best regards, Bruno |
Hi Sale,
have a look at http://www.cfd-online.com/Forums/ope...directory.html Maybe you need the Path to Qt4.3.5 by PATH=...whereeverItIs/Qt4.3.5/bin:$Paraview3.3 (this was somewhere on the forum as well but I cannot remember where, sorry) For me it worked perfectly... Hope this helps Kathrin |
Bruno,
if I follow OpenFoam example: mkdir -p $FOAM_RUN cp -r $FOAM_TUTORIALS $FOAM_RUN cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity blockMesh icoFoam everything looks ok, but then, with paraFoam, the result is: /home/openfoam/OpenFOAM/OpenFOAM-1.7.0/bin/paraFoam: line 132: paraview: command not found I supposed Paraview is not installed. What do I have to do? kathrin_kissling, what do you mean with: Maybe you need the Path to Qt4.3.5 by PATH=...whereeverItIs/Qt4.3.5/bin:$Paraview3.3 ? Should I add this path to the bashrc file that is in /etc? Thank you both for the quick answer. Sale |
Anyway
qmake --version gives me bash: qmake: command not found |
Hi Sale,
How exactly did you install CentFOAM? If you used the install script: Quote:
./centFOAMInstall paraview Bruno |
