error while installing
I get the following error while installation of OpenFOAM 1.7. The OS is RedHat. make[2]: *** [/home/akonduri/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/IFCLookUpTableGen] Error 1 make[2]: Leaving directory `/home/akonduri/OpenFOAM/OpenFOAM-1.7.0/applications/utilities/thermophysical/IFCLookUpTableGen' make[1]: *** [IFCLookUpTableGen] Error 2 make[2]: Entering directory `/home/akonduri/OpenFOAM/OpenFOAM-1.7.0/applications/utilities/thermophysical/mixtureAdiabaticFlameT' g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/akonduri/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/akonduri/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/akonduri/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/mixtureAdiabaticFlameT.o -L/home/akonduri/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt \ -lspecie -lOpenFOAM -liberty -ldl -lm -o /home/akonduri/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT /usr/bin/ld: cannot find -lOpenFOAM collect2: ld returned 1 exit status make[2]: *** [/home/akonduri/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT] Error 1 make[2]: Leaving directory `/home/akonduri/OpenFOAM/OpenFOAM-1.7.0/applications/utilities/thermophysical/mixtureAdiabaticFlameT' make[1]: *** [mixtureAdiabaticFlameT] Error 2 make[1]: Target `application' not remade because of errors. make[1]: Leaving directory `/home/akonduri/OpenFOAM/OpenFOAM-1.7.0/applications/utilities/thermophysical' make: *** [thermophysical] Error 2 make: Target `application' not remade because of errors. |
Greetings Aditya,
Knowing which version of RedHat would also help... Also, what is the version of gcc you are using? Run this: Code:
gcc -v As for the error: Quote:
./Alwmake > make.log 2>&1 Additionally, AFAIK, there is a package for CentOS named centfoam that might help you install OpenFOAM in RedHat: CentFOAM - OpenFOAM for CentOS.x86_64 Best regards, Bruno |
