Error "cannot find -lz"
I encountered compilation error when installing OpenFOAM 1.7.1 on my ubuntu 9.0.4 The error message was shown when entering the src/OpenFOAM folder, which is "cannnot find -lz" This was also shown when compiling Scotch decomposition library I am not sure what the z library is. I assumed it is zlib as I noticed that in my ThirdParty-1.7.1, there was not zlib-1.2.3 folder originally when unpacking the downloaded zip file. So, I manually installed z library. This solved other compilation errors when zlib.h was missing. However, the error due to "cannot find -lz" is still there. Does anyone have suggestion? Thanks very much in advance! |
Problem solved after copy libz.so to /usr/local/lib
Greetings Yu Shi,
The package you were missing for libz is this: Code:
zlib1g-dev Best regards, Bruno |
