Paraview 3.8 on Ubuntu 10.10 (qt 4.7)
Hi, i compiled OpenFoam sucessfully on ubuntu 10.10, but paraview is not building.
The error is easy to understand Code:
CMake Warning at CMakeLists.txt:105 (MESSAGE): Thanks |
Another question,
Will the paraview installed via apt-get have the same features as the one compiled from ThirdParty? I installed and it seems to be working fine, but i don't know if i will find some problems in the future. thanks |
Old paraview versions used to lack an OpenFoam plugin to view results without converting them to VTK. Paraview 3.8 now has a native OpenFoam reader, so I don't think it will have any negative side effect using the repository version.
Yes, the overall behavior of OpenFoam seems ok like you said.
The only problem now is with the particles. While opening the VTK files the only option is Legacy VTK files, and it gives me the following error: Code:
ERROR: In /build/buildd/paraview-3.8.1/Servers/ServerManager/vtkSMWriterFactory.cxx, line 337 |
Greetings to all!
Guilherme, what Anton meant is to use the internal reader to open OpenFOAM cases. Namely: Quote:
Best regards, Bruno |
Hi Lindner, Hi all,
I am having the same problem that you stated in your first post (but with an Arch Linux distribution, cmake 2.8.2, qt 4.7.0). Has anyone found a solution to it yet? Best regards, GT PS: Officially supported is qt 4.6 - is there any, like 'compatibility option' for compiling? |
Ok, solved for me. Workaround was:
- downgrade to qt-4.6.3 - compile & install - upgrade to qt-4.7 again. Regards, GT |
maybe you should install the libqt-devel plugin
when I am installing the ParaView 3.8, I have a similar problem, so I install the libqtwebkit-devel, its done |
Paraview 3.8 on Fedora 15 Qt 4.7
Had the problem with NOTFOUND QT_QTASSISTANTCLIENT_INCLUDE_DIR (ADVANCED) on Fedora 15. Installing qt-webkit, qt-assistant, qt-assistant-adp and qt-assistant-adp-devel has solved the problem for me
Additionally I had to run: sed -i -e 's=ptrdiff_t=std::ptrdiff_t=' paraview-3.8.0/VTK/Utilities/vtkmetaio/metaUtils.cxx to get Paraview compiled (see http://www.cfd-online.com/Forums/ope...ra-15-x64.html) and had linked /usr/bin/qmake-qt4 to /usr/bin/qmake Thanks to the input from this forum |
Can you show me more details about how to downgrade to qt-4.6.3. I am quite new to Linux(ubuntu). I met the same problem. Thank you in advance. |
well, the process would be to uninstall the installed version using Code:
sudo apt-get remove [installed version package name] Code:
dpkg --get-selections | grep libqt Code:
dpkg -i [package.deb] Afterwards, remove the older package that was required to compile openfoam Code:
dpkg -r [package] Code:
sudo apt-get install [package name from the beginning / recent version from repos] a) this is a workaround, not a solution b) it would be better to fix the package requirement in the openfoam/parafoam sources c) my post from above, and the incident when it worked is now over half a year ago. Maybe the sources on openfoam.com are updated and you don't even need that fix anymore. So watch out for changes. I don't know if it is relevant here, but when building openfoam on OpenSuSE recently (openfoam provides precompiled rpm packages for OpenSuSE 12.1 btw.), I found this website very helpful: http://albertopassalacqua.com/?p=973 I hope this helps, regards, gt PS: Before typing all the commands I posted above, I recommend you try to find out what they really do, especially if you want to get to know the debian package manager apt better. You can either browse the web for that or use "man [command]" to display the manual page for the given command. |
