Installation OpenFOAM-1.7.x with wmakeScheduler |
May 16, 2012, 02:10 |
#21 | |
Tobias Holzmann
Rep Power: 51 |
Hi Shaun,
well you can use the following command: Code:
./Allwmake 1> make.log 2> error.log Upload it and we can help you Tobi You installed the necessary packages ? Are you compiling 1.7.x? Quote:
May 16, 2012, 11:22 |
#22 |
Shaun
Rep Power: 13 |
Hey again,
Thanks for the response, Tobi. I am installing OpenFOAM-2.1.x (Repository Release) Currently, it is OpenFOAM-2.1.0 Seeing as it's not 1.7.0, I created a new thread to post to. In reference to installing the necessary packages: I have installed all of the packages that were brought to my attention. However, there may be some that were not mentioned since the closest Linux distro to RHEL 6.2 on the OpenFOAM installation tutorial is Fedora 15/16. (I mention these in more detail in the new thread.) Therefore, I simply installed as if my distro was Fedora 15 or 16 and downloaded the packages described as necessary for installation on these distros. Finally I uploaded a portion of the error log in the new thread. Check it out if you'd like. Feel free to let me know any ways I can clean it up to make it easier to read/debug. Thanks again, Shaun Last edited by socon009; May 16, 2012 at 11:30. Reason: Forgot to mention... |
May 16, 2012, 16:01 |
#23 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Shaun and Tobi,
@Tobi: Quote:
And it's really simple when we have a single log file: search for the first or second occurrence of "Error " and voilą, reason for the problem found. @Shaun: I'm heading now to the other thread: http://www.cfd-online.com/Forums/ope...hel-6-2-a.html Best regards, Bruno
June 18, 2014, 07:34 |
#24 |
Rep Power: 11 |
Hello there,
first of all my name is Christopher and I stumbled across this thread while searching for an answer for the parallel compilation of OpenFoam. I am using OpenFoam 2.3.0 on Ubuntu 14.04. I followed the description of the official support of using the wmakeScheduler but compilation only works on one processor. Also the hints in this thread of setting up the hostname does not fix the problem. Do you have any up-to-date hint for me? Is there any known bug? Best Regards Chris |
June 21, 2014, 16:07 |
#25 |
Bruno Santos
Rep Power: 128 |
Greetings Chris and welcome to the forum!
Using wmakeScheduler is only useful when using more than one machine in parallel. Clearer instructions for installing OpenFOAM 2.3.0 on Ubuntu 14.04 are given here: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04 - there you've find how to build with multiple cores with a single machine. Best regards, Bruno
June 24, 2014, 05:06 |
#26 |
Rep Power: 11 |
Hi wyldckat,
this perfectly answered my question. Thank you very much. Nice Forum! Chris |
wmakescheduler |
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x | wyldckat | OpenFOAM Bugs | 18 | October 21, 2010 05:51 |
Critical errors during OpenFoam installation in OpenSuse 11.0 | amscosta | OpenFOAM | 5 | May 1, 2009 14:06 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
