[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10
Old   February 7, 2011, 10:22
Gijsbert Wierink
gwierink is on a distinguished road
I think that
sudo sh -c "echo deb http://www.openfoam.com/download/ubuntu <maverick> main >> /etc/apt/sources.list"
should be
sudo sh -c "echo deb http://www.openfoam.com/download/ubuntu maverick main >> /etc/apt/sources.list"
Does that help?
Regards, Gijs
gwierink is offline   Reply With Quote
Old   February 7, 2011, 10:27
Rogelio Chovet
chichovet is on a distinguished road
Originally Posted by gwierink View Post
I think that
should be
Does that help?
worked perfectly
Thank You very much
chichovet is offline   Reply With Quote
Old   February 7, 2011, 10:41
Gijsbert Wierink
That's good to hear!
Regards, Gijs
Old   February 21, 2011, 15:56
Vishal Nandigana
nandiganavishal is on a distinguished road
Dear Foamers,
I am trying to install OF-1.7.1 on a RedHat cluster whose gcc version is 4.4.4 and it is a 64 bit machine. I was following the steps from the site but I get the following errors when I try to run ./Allwmake
make: *** [/turing/home/lee263/OpenFOAM/OpenFOAM-1.7.1/lib/linuxPPC64GccDPOpt/libdynamicMesh.so] Error 1
+ wmake libso dynamicFvMesh
/bin/sh: /turing/home/lee263/OpenFOAM/OpenFOAM-1.7.1/wmake/bin/linuxPPC64Gcc/wmkdep: No such file or directory
Further I get the following error when I do a foamInstallation test.
Checking basic setup...
Shell: tcsh
Host: turing-4.turing.cse.uiuc.edu
OS: Linux version 2.6.32.26-175.fc12.ppc64
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /turing/home/lee263/OpenFOAM yes yes
$WM_PROJECT_USER_DIR ...ng/home/lee263/OpenFOAM/lee263-1.7.1 no no
$WM_THIRD_PARTY_DIR ...ome/lee263/OpenFOAM/ThirdParty-1.7.1 yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR .../home/lee263/OpenFOAM/OpenFOAM-1.7.1 yes yes yes
$FOAM_APPBIN .../applications/bin/linuxPPC64GccDPOpt no yes
$FOAM_SITE_APPBIN ...AM/site/1.7.1/bin/linuxPPC64GccDPOpt no no
$FOAM_USER_APPBIN .../applications/bin/linuxPPC64GccDPOpt no no
$WM_DIR ...lee263/OpenFOAM/OpenFOAM-1.7.1/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...penFOAM-1.7.1/lib/linuxPPC64GccDPOpt yes yes yes
$FOAM_SITE_LIBBIN ...AM/site/1.7.1/lib/linuxPPC64GccDPOpt no no
$FOAM_USER_LIBBIN .../lee263-1.7.1/lib/linuxPPC64GccDPOpt no no
$MPI_ARCH_PATH ...latforms/linuxPPC64Gcc/openmpi-1.4.1 yes yes yes
Third party software
Software Version Location
gcc 4.4.4 /usr/bin/gcc
gzip 1.3.12 /bin/gzip
tar 1.22 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /turing/home/lee263/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxPPC64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
*** The foam installation contains 1 critical error(s)
*** Review the output for warning messages and consult
*** the installation guide for trouble shooting.
done.
Could you guys kindly help me out.
Thanks
nandiganavishal is offline   Reply With Quote
Old   February 22, 2011, 00:57
Gijsbert Wierink
Hi Vishal,
Was the dynamicMesh error really the first one, or did you run into trouble earlier? Do you have a build log? If so, just look for "rror" and try to find the very first problem, this may be in ThirdParty already. Also, it seems you are using openmpi as provided in ThirdParty. On a cluster it's probably better to find the right MPI paths etc and use those. When I compiled on a cluster I found that I needed to use several local libraries instead of ThirdParty ones and also make my own wmake rules for the cluster's compiler. Have a look here, where I explain the steps that worked for me ...
Regards, Gijs
Old   February 22, 2011, 10:47
Vishal Nandigana
Thanks for the reply. I will look into the link and would get back to you soon.
Old   February 24, 2011, 11:20
Vishal Nandigana
Dear Gijsbert,
I did go through your .pdf file and you were right the first error was in Thirdparty and in choosing the MPI and flex command was not found.
Here are the first set of errors,
./Allwmake
gcc -m64 -mcpu=power5+ -Wall -O3 -fPIC dirToString.c -o /turing/home/nandiga1/OpenFOAM/OpenFOAM-1.7.1/wmake/bin/linuxPPC64Gcc/dirToString
flex wmkdep.l
make: flex: Command not found
make: *** [/turing/home/nandiga1/OpenFOAM/OpenFOAM-1.7.1/wmake/bin/linuxPPC64Gcc/wmkdep] Error 127
Start ThirdParty Allwmake
Compile specific mpi libraries
+ cd openmpi-1.4.1
+ make distclean
+ rm -rf /turing/home/nandiga1/OpenFOAM/ThirdParty-1.7.1/platforms/linuxPPC64Gcc/openmpi-1.4.1
+ unset mpiWith
+ '[' -n '' ']'
+ ./configure --prefix=/turing/home/nandiga1/OpenFOAM/ThirdParty-1.7.1/platforms/linuxPPC64Gcc/openmpi-1.4.1 --disable-mpirun-prefix-by-default --disable-orterun-prefix-by-default --enable-shared --disable-static --disable-mpi-f77 --disable-mpi-f90 --disable-mpi-cxx --disable-mpi-profile
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking how to create a ustar tar archive... gnutar
== Configuring Open MPI
The cluster supports MPICH-Mx and i was told MPICH_GM and MX are the same, so I changed in the cshrc and settings.csh the following things
in cshrc file
# WM_MPLIB = SYSTEMOPENMPI | OPENMPI | MPICH | MPICH-GM | HPMPI | MPI | QSMPI
WM_MPLIB = MPICH-GM
in settings.csh file
case MPICH-GM:
setenv MPI_ARCH_PATH /opt/mpich-mx-gcc-32/
setenv MPICH_PATH $MPI_ARCH_PATH
setenv GM_LIB_PATH /opt/mx/lib64
Still the same problem exits. Further, flex was installed in the cluster, still the same flex error was found. I want to know where should the flex be installed.
Thanks a lot for the help.
Regards
Vishal
Old   February 24, 2011, 11:41
Gijsbert Wierink
Dear Vishal,
Clearly flex is a problem to deal with. So, you say it is installed on the system. But apparently OpenFOAM can't find it. One option I read here is to find out where flex lives using e.g. "which flex" and then add it to your PATH. On my laptop flex lives in /usr/bin/flex, so I would add the following to my .bashrc
export PATH=/usr/bin/flex:$PATH
alias flex++='flex -+'
Does that help any? Otherwise you could also compile flex in your own account, if you can do that on your cluster ...
Regards, Gijs
Old   February 24, 2011, 12:42
Vishal Nandigana
Dear Gijsbert,
I did try which flex but couldn't see any file, hence I decided to download and install the same in my own account and added the path to the cshrc file and now compiled ./Allwmake. I didn't get any flex error. That problem is resolved, however, I get some errors regarding Thirdparty. Following were the first error that I observed. Can you give your comments for the same.
make[2]: Entering directory `/turing/home/nandiga1/OpenFOAM/ThirdParty-1.7.1/scotch_5.1/src/libscotch'
gcc -O3 -fPIC -DCOMMON_TIMING_OLD -Drestrict=__restrict -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_PTHREAD -DSCOTCH_RENAME -DSCOTCH_VERSION=\""5.1"\" dummysizes.c -o dummysizes -lz -lm -lrt
./dummysizes library.h scotch.h
./dummysizes libraryf.h scotchf.h
gcc -O3 -fPIC -DCOMMON_TIMING_OLD -Drestrict=__restrict -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_PTHREAD -DSCOTCH_RENAME -c arch.c -o arch.o
gcc -O3 -fPIC -DCOMMON_TIMING_OLD -Drestrict=__restrict -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_PTHREAD -DSCOTCH_RENAME -c arch_build.c -o arch_build.o
^Cmake[2]: *** wait: No child processes. Stop.
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [scotch] Error 2
make: *** [scotch] Interrupt
Thanks
Vishal
Old   February 25, 2011, 02:35
Gijsbert Wierink
Dear Vishal,
Good, so the flex issue is solved .
I see in your error message "^C". Did you press Ctrl+C because it got stuck or something?
For recompiling, did you clean up? Perhaps I'm a bit of a "compiling purist", but before (re)compiling I always do
rmdepall
wcleanLnIncludeAll
just to remove any weird traces of badly compiled code. So, perhaps you could do
cd $WM_THIRD_PARTY_DIR
rmdepall
wcleanLnIncludeAll
cd $WM_PROJECT_DIR
rmdepall
wcleanLnIncludeAll
and try again ...
Regards, Gijs
Old   February 25, 2011, 10:56
Vishal Nandigana
Dear Gijsbert,
I did give Ctrl C when I saw the error in the first instant. However, I again compiled it to see what were other errors (didn't clean before compilation) and I created a make file for the same (using ./Allwmake >> make.log &). When I do this I see that along with the output displayed in the make file some error messages were also displayed in the terminal, I wonder why that is happening. I did try your command in the pdf file you had written for installation in cluster (./Allwmake >make.log 2>make.err &) but it gives me error. Anyways regarding other errors when I tried to build I find that in all
applications it gives the same error that is
make[2]: Leaving directory `/turing/home/nandiga1/OpenFOAM/OpenFOAM-1.7.1/applications/utilities/thermophysical/IFCLookUpTableGen
make[2]: Entering directory `/turing/home/nandiga1/OpenFOAM/OpenFOAM-1.7.1/applications/utilities/thermophysical/mixtureAdiabaticFlameT'
make[2]: Leaving directory `/turing/home/nandiga1/OpenFOAM/OpenFOAM-1.7.1/applications/utilities/thermophysical/mixtureAdiabaticFlameT'
Thanks
Old   February 25, 2011, 11:44
Gijsbert Wierink
Hi Vishal,
Strange that splitting the log doesn't work. But it doesn't matter really, it's just convenient. make leaving and entering directories is not an error, it should do that. Do you have anywhere in your log somewhere saying "Error"? Does your foamInstallationTest give any errors now? If so, I really suggest you clean the installation as I mentioned above and try again (after you made flex known to the installation ...).
Regards, Gijs
Old   February 25, 2011, 12:08
Vishal Nandigana
Dear Gijsbert,
I am cleaning the entire thing and rebuilding it to see the errors using the commands you had mentioned by typing the following in the home directory.
rmdepall
wcleanLnIncludeAll
I would recompile once I finish cleaning them.
Just for your information, the errors I got from previous build
make[2]: *** [/turing/home/nandiga1/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxPPC64GccDPOpt/IFCLookUpTableGen] Error 1
make[1]: *** [IFCLookUpTableGen] Error 2
Making dependency list for source file mixtureAdiabaticFlameT.C
could not open file ListI.H for source file mixtureAdiabaticFlameT.C
could not open file List.C for source file mixtureAdiabaticFlameT.C
could not open file SubList.H for source file mixtureAdiabaticFlameT.C
could not open file SLList.H for source file mixtureAdiabaticFlameT.C
could not open file parRun.H for source file mixtureAdiabaticFlameT.C
could not open file IStringStream.H for source file mixtureAdiabaticFlameT.C
could not open file sigFpe.H for source file mixtureAdiabaticFlameT.C
could not open file sigInt.H for source file mixtureAdiabaticFlameT.C
could not open file sigQuit.H for source file mixtureAdiabaticFlameT.C
could not open file sigSegv.H for source file mixtureAdiabaticFlameT.C
could not open file dictionary.H for source file mixtureAdiabaticFlameT.C
could not open file IFstream.H for source file mixtureAdiabaticFlameT.C
could not open file OSspecific.H for source file mixtureAdiabaticFlameT.C
could not open file specieThermo.H for source file mixtureAdiabaticFlameT.C
could not open file janafThermo.H for source file mixtureAdiabaticFlameT.C
could not open file perfectGas.H for source file mixtureAdiabaticFlameT.C
could not open file mixture.H for source file mixtureAdiabaticFlameT.C
/usr/bin/ld: cannot find -lOpenFOAM
collect2: ld returned 1 exit status
make[2]: *** [/turing/home/nandiga1/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxPPC64GccDPOpt/mixtureAdiabaticFlameT] Error 1
make[1]: *** [mixtureAdiabaticFlameT] Error 2
make[1]: Target `application' not remade because of errors.
make: *** [thermophysical] Error 2
make: Target `application' not remade because of errors.
and when I did do a foamInstallation test from my previous build and got 1 critical error.
Here is test results
Executing ./foamInstallationTest:
Shell: tcsh
$WM_PROJECT_INST_DIR /turing/home/nandiga1/OpenFOAM yes yes
$WM_PROJECT_USER_DIR ...ome/nandiga1/OpenFOAM/nandiga1-1.7.1 no no
$WM_THIRD_PARTY_DIR ...e/nandiga1/OpenFOAM/ThirdParty-1.7.1 yes yes
$WM_PROJECT_DIR ...ome/nandiga1/OpenFOAM/OpenFOAM-1.7.1 yes yes yes
$FOAM_APPBIN .../applications/bin/linuxPPC64GccDPOpt yes yes yes
$WM_DIR ...ndiga1/OpenFOAM/OpenFOAM-1.7.1/wmake yes yes yes
$FOAM_USER_LIBBIN ...andiga1-1.7.1/lib/linuxPPC64GccDPOpt no no
tar 1.22 /bin/tar
icoFoam
OpenFOAM settings : /turing/home/nandiga1/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxPPC64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
done.
Thanks
Vishal
Old   February 25, 2011, 12:26
Vishal Nandigana
Dear Gijsbert,
I am building it again after cleaning everything, the first error I get is this
[nandiga1@turing-4 OpenFOAM-1.7.1]$ ./Allwmake >> make.log &
[1] 6144
[nandiga1@turing-4 OpenFOAM-1.7.1]$ + cd scotch_5.1/src
+ mkdir -p /turing/home/nandiga1/OpenFOAM/OpenFOAM-1.7.1/lib/linuxPPC64GccDPOpt/openmpi-1.4.1
+ make ptscotch
/usr/bin/ld: skipping incompatible /turing/home/nandiga1/OpenFOAM/ThirdParty-1.7.1/platforms/linuxPPC64Gcc/openmpi-1.4.1/lib/libmpi.so when searching for -lmpi
/usr/bin/ld: cannot find -lmpi
make[2]: *** [dummysizes] Error 1
make[1]: *** [ptscotch] Error 2
make: *** [ptscotch] Error 2
+ cd metis-5.0pre2
+ cpMakeFiles metis
+ set +x
I would like to say that the cluster I use support MPICH-MX. Could you suggest how to resolve the following error.
Thanks
Vishal
Old   February 26, 2011, 02:17
Gijsbert Wierink
Dear Vishal,
I think it is best to make your own wmake rules, as I explain in the document I shared with you. For MPI in particular, you need to find out where the MPI libraries live and make those paths known by adjusting the WM_MPLIB and MPICH_PATH in $WM_PROJECT_DIR/etc/bashrc, as explained on p.5 and in Appendix A of my notes.
Regards, Gijs
Old   February 27, 2011, 06:38
Default install problems
  #36
Tobias
podracer is on a distinguished road
Dear all,
I'm a newbie on openfoam. I tried to install it on ubuntu 10.10 according to the instructions. Now when I write:
ecoFoam -help
I receive how to start (with -parallel etc)
Then I try to start
ecoFoam
but receive the message
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/tobias/system/controlDict at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 61.
FOAM exiting
I have checked and it seems like the install has not created any files in my home directory. Could it be my user configuration that has failed for some reason and how can I fix it?
podracer is offline   Reply With Quote
Old   February 27, 2011, 08:16
Retired Super Moderator
Bruno Santos
Greetings to all! Tobias, welcome to the forum!
I think you skipped an important section of the installation instructions: Getting Started
Also, refer to the user guide as stated in that section, to start learning how to use OpenFOAM. It's not as easy as simply running the solver
Best regards and good luck!
Bruno
Old   February 28, 2011, 19:34
Vishal Nandigana
Dear Gijsbert
I have followed your document and incorporated changes to the settings.csh and cshrc file to the following to include the MPI parth as that was the first error
Here is the modified changes to settings.csh file
# Communications library
unsetenv MPI_ARCH_PATH MPI_HOME
switch ("$WM_MPLIB")
case MPT:
setenv GM_LIB_PATH /opt/mpich-mx-gcc-32/lib
_foamAddPath $MPI_ARCH_PATH/bin
_foamAddLib $MPI_ARCH_PATH/lib
_foamAddLib $GM_LIB_PATH
and the cshrc file
setenv WM_MPLIB MPT
But I get the same error.
-DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_PTHREAD -DSCOTCH_RENAME -DSCOTCH_PTSCOTCH" CC="mpicc" SCOTCHLIB=ptscotch \
scotch.h \
scotchf.h \
libptscotch.so \
libptscotcherr.so \
libptscotcherrexit.so
mpicc -O3 -fPIC -DCOMMON_TIMING_OLD -Drestrict=__restrict -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_PTHREAD -DSCOTCH_RENAME -DSCOTCH_PTSCOTCH -DSCOTCH_VERSION=\""5.1"\" dummysizes.c -o dummysizes -lz -lm -lrt
make[2]: Leaving directory `/turing/home/nandiga1/OpenFOAM/ThirdParty-1.7.1/scotch_5.1/src/libscotch'
make[1]: Leaving directory `/turing/home/nandiga1/OpenFOAM/ThirdParty-1.7.1/scotch_5.1/src/libscotch'
Kindly let me know your suggestion.
Thanks
Vishal
Old   March 1, 2011, 01:08
Gijsbert Wierink
Hi Vishal,
If your MPI lives in /opt/mpich-mx-gcc-32, then it looks alright. But the system still can't find mpi.h or similar, so did you make new wmake rules for your own compiler? One needs to specify new rules and paths in $WM_PROJECT_DIR/wmake/rules. I called the compiler crayxt, so I made a directory $WM_PROJECT_DIR/wmake/rules/crayxt, where I specified the files in Appendix B of my report (p.18-22). In particular, if you use the MPT library, you need to specify what that means for the compiler, i.e. you need to create $WM_PROJECT_DIR/wmake/rules/crayxt/mplibMPT in that case. Just follow the recipe in Section 3.3 and Appendix B. Then you also need to make sure that these paths are added in settings.sh and bashrc in $WM_PROJECT_DIR/etc (with the paths and names for your system of course).
Regards, Gijs
Old   July 1, 2014, 07:55
Jens
jensi_t is on a distinguished road
I had a similar problem with foam-ext-3.1 on OpenSuse 13.1. I think just adding
export OPENMPI_DIR=/usr/lib64/mpi/gcc/openmpi (installation directory of openmpi)
export OPENMPI_BIN_DIR= \$OPENMPI_DIR\/bin
to foam-extend-3.1/etc/prefs.sh
and running foam-extend-3.1/src/Pstream/Allwmake solved the problem.
jensi_t is offline   Reply With Quote
OpenFOAM 1.7.1. using openmpi on Ubuntu 12.04 dasMopo OpenFOAM Installation 5 February 17, 2013 10:14
Openfoam 2.1 installation in ubuntu 12.04 jsm OpenFOAM Installation 11 May 7, 2012 04:56
OpenFOAM vs Ubuntu 10.10 64 bit vkrastev OpenFOAM Installation 12 April 23, 2011 10:14
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
OpenFOAM Installation Ubuntu 9.04 Problems Sumontro OpenFOAM Installation 8 July 21, 2009 21:40
