Compiling OpenFOAM 1.7.1 on Ubuntu 10.10
Old   October 19, 2010, 09:39
Default Compiling OpenFOAM 1.7.1 on Ubuntu 10.10
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am trying to install OpenFOAM 1.7.1 on Ubuntu Maverick. Everything goes well, until I install Paraview.
Following this page, I get:
samiam@penrose:~/OpenFOAM/ThirdParty-1.7.1$ ./makeParaView
ParaView_SOURCE_DIR=/home/samiam/OpenFOAM/ThirdParty-1.7.1/paraview-3.8.0
ParaView_BINARY_DIR=/home/samiam/OpenFOAM/ThirdParty-1.7.1/platforms/build-linux64Gcc/paraview-3.8.0
ParaView_DIR=/home/samiam/OpenFOAM/ThirdParty-1.7.1/platforms/linux64Gcc/paraview-3.8.0
date-stamp: 2010-03-26
Build stages selected
    -config   true
    -make     true
    -install  true
Features selected
    mesa      false
    mpi       false
    python    false
    qt        true
Version information
    version   3.8.0
    major     3.8
removing old build directory
Configuring paraview-3.8.0 (major version: 3.8)
    MPI    support : false
    Python support : false
    MESA   support : false
    Qt dev support : true
    Source         : /home/samiam/OpenFOAM/ThirdParty-1.7.1/paraview-3.8.0
    Build          : /home/samiam/OpenFOAM/ThirdParty-1.7.1/platforms/build-linux64Gcc/paraview-3.8.0
    Target         : /home/samiam/OpenFOAM/ThirdParty-1.7.1/platforms/linux64Gcc/paraview-3.8.0
cmake -DCMAKE_INSTALL_PREFIX:PATH=/home/samiam/OpenFOAM/ThirdParty-1.7.1/platforms/linux64Gcc/paraview-3.8.0 -DVTK_USE_TK:BOOL=OFF -DBUILD_SHARED_LIBS:BOOL=ON -DVTK_USE_RPATH:BOOL=OFF -DCMAKE_BUILD_TYPE:STRING=Release -DPARAVIEW_INSTALL_DEVELOPMENT:BOOL=ON -DPARAVIEW_GENERATE_PROXY_DOCUMENTATION:BOOL=ON -DPARAVIEW_GENERATE_PROXY_DOCUMENTATION=OFF -DPARAVIEW_BUILD_QT_GUI=ON /home/samiam/OpenFOAM/ThirdParty-1.7.1/paraview-3.8.0
./makeParaView: 295: cmake: not found
    Starting make
make: *** No targets specified and no makefile found.  Stop.
Command exited with non-zero status 2
0.00user 0.00system 0:00.00elapsed 0%CPU (0avgtext+0avgdata 4400maxresident)k
0inputs+0outputs (0major+330minor)pagefaults 0swaps
    Done make
    Installing ParaView to /home/samiam/OpenFOAM/ThirdParty-1.7.1/platforms/linux64Gcc/paraview-3.8.0
make: *** No rule to make target `install'.  Stop.
    Installation complete for paraview-3.8.0
    Set environment variables:
        export ParaView_DIR=/home/samiam/OpenFOAM/ThirdParty-1.7.1/platforms/linux64Gcc/paraview-3.8.0
        export PATH=$ParaView_DIR/bin:$PATH
        export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.8
Done
    -config   true
    -make     true
    -install  true
Features selected
    mesa      false
    mpi       false
    python    false
    qt        true
Version information
    version   3.8.0
    major     3.8
    MPI    support : false
    Starting make
0inputs+0outputs (0major+329minor)pagefaults 0swaps
    Done make
Done
Can you help to fix this??
Thanks a lot,
Samuele.
samiam1000 is offline   Reply With Quote
Old   October 19, 2010, 10:25
Retired Super Moderator
Bruno Santos
Greetings Samuele,
CMake is missing in your Ubuntu box. You can install it by running:
sudo apt-get install cmake
But if you don't feel like spending time building a custom version of ParaView, you can:
  1. Install ParaView 3.8.1 built for Ubuntu 10.10, by running:
    sudo apt-get install paraview
  2. Quote:
    Originally Posted by http://www.cfd-online.com/Forums/blogs/wyldckat/317-using-official-pre-built-paraview-3-8-0-version-openfoam.html
    Now open the file "$WM_PROJECT_DIR/bin/paraFoam" in your favorite simple text editor and replace every entry ".OpenFOAM" with ".foam". Now save and close the file.
    And voilá, you now should have a fully working paraFoam script at your disposal! Along with ParaView 3.8.0, with no further building required
    Well, in this case, ParaView 3.8.1
Best regards,
Bruno
Old   October 19, 2010, 11:29
David Gaden
marupio is on a distinguished road
I hope you're not facing the mysterious "missing cmake" problem that I went through. See:
http://www.cfd-online.com/Forums/ope...directory.html
Something that the video driver update did fixed. Surely it's just an environment variable or something...
marupio is offline   Reply With Quote
Old   October 19, 2010, 18:11
Bruno Santos
Greetings David,
You wouldn't by any chance still have that Linux box up and running, would you? Because that error of an application not starting and giving the error "file not found" or something like that, is sometimes related to an actually missing and unnamed library that the application depends on.
In your case, running the following command, on a working system and on a non working system, would help isolate the problem:
ldd cmake
I say unnamed, because ldd might not be able to say which library the application really depends on, in case it isn't already available in the system! Therefore isolation of the missing library can only occur by comparing the differences between in a working and in a non-working system.
Best regards,
Bruno
Old   November 24, 2010, 08:00
Default Packs are now available for ubuntu 10.10
OpenCFD
opencfd is on a distinguished road
Packs are now available for ubuntu 10.10:
http://www.openfoam.com/download/ubuntu.php
opencfd is offline   Reply With Quote
OpenFoam 1.7.1 in Ubuntu 10.04 won't start working Leech OpenFOAM Installation 8 August 10, 2014 20:42
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
OpenFOAM on non-English Ubuntu distribution fabian_roesler OpenFOAM 3 January 11, 2010 07:16
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
