Uninstall Openfoam
Like Tree7Likes
  • 7 Post By wyldckat
Old   June 3, 2014, 14:31
Default Uninstall Openfoam
Korawin Sriniratsai
korawin10287 is on a distinguished road
Hi all
I just install the newest version of Openfoam (2.3.0) on my new machine. After that I found that it cannot compile the turbinePisoFoam code so I need to use the older version of Openfoam (2.1.0).
I tried to follow the instruction on git repository but it doesn't work for me, so I'm thinking of completely remove all the content of 2.3.0 and install the 2.1.0 version. I also follow the uninstall instruction searched from Google but it doesn't work for me too (post from 2007) Does anyone have any idea on this ?
Thank you very much.
korawin10287 is offline   Reply With Quote
Old   June 3, 2014, 17:37
Retired Super Moderator
Bruno Santos
Greetings Korawin and welcome to the forum!
Well, technically you can have more than one version/variant of OpenFOAM installed in your machine. Instructions on how to have more than one version, as well as to learn more on how to get around OpenFOAM's shell environment, are given here: http://openfoamwiki.net/index.php/In...with_the_Shell
As for uninstalling OpenFOAM 2.3.0, it depends on how you installed it in the first place:
  • If it was installed from source code, you simply have to remove the folders where it was installed, when you followed the installation instructions.
  • If it was installed from Deb or RPM package, you need to use the respective opposite command. For example, to remove the Deb packages on Ubuntu, run:
    sudo apt-get remove openfoam230 paraviewopenfoam410
Best regards,
Bruno
Old   June 11, 2014, 12:33
Korawin Sriniratsai
Thank you very much. That's run properly
Best regards,
Bruno
uninstall remove
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
OpenFOAM Foundation Releases OpenFOAM v2.3.0 opencfd OpenFOAM Announcements from OpenFOAM Foundation 3 December 23, 2014 03:43
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 07:14
