x86_64-suse-linux/bin/ld: cannot find -liberty
Old   December 16, 2010, 01:55
Angry x86_64-suse-linux/bin/ld: cannot find -liberty
Stefan
preibie is on a distinguished road
Hallo everybody,
I want to change from OpenFOAM 1.6 to 1.7. So I downloaded OpenFOAM white git as explained on openfoam.com. The next step is to compile so I write ./Allwmake and this is the output message:
make[2]: Entering directory `/home/preibisch/OpenFOAM/OpenFOAM-1.7.x/applications/utilities/thermophysical/mixtureAdiabaticFlameT'
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/preibisch/OpenFOAM/OpenFOAM-1.7.x/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/preibisch/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.7.x/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/mixtureAdiabaticFlameT.o -L/home/preibisch/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt \
-lspecie -lOpenFOAM -liberty -ldl -lm -o /home/preibisch/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT
/usr/lib64/gcc/x86_64-suse-linux/4.4/../../../../x86_64-suse-linux/bin/ld: cannot find -liberty
collect2: ld returned 1 exit status
make[2]: *** [/home/preibisch/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT] Fehler 1
make[2]: Leaving directory `/home/preibisch/OpenFOAM/OpenFOAM-1.7.x/applications/utilities/thermophysical/mixtureAdiabaticFlameT'
make[1]: *** [mixtureAdiabaticFlameT] Fehler 2
make[1]: Das Target »application« wurde wegen Fehlern nicht aktualisiert.
make[1]: Leaving directory `/home/preibisch/OpenFOAM/OpenFOAM-1.7.x/applications/utilities/thermophysical'
make: *** [thermophysical] Fehler 2
make: Das Target »application« wurde wegen Fehlern nicht aktualisiert
I don't know what is wrong ! I checked gcc and flex and they are up to date.
Can somebody help me?
Preibie
preibie is offline   Reply With Quote
Old   December 16, 2010, 02:20
Stefan
I have run the foamInstallationTest and this is the result:
Checking basic setup...
Shell: bash
Host: Fluent64-2
OS: Linux version 2.6.31.12-0.2-desktop
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/preibisch/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/preibisch/OpenFOAM/preibisch-1.7.x yes no
$WM_THIRD_PARTY_DIR .../preibisch/OpenFOAM/ThirdParty-1.7.x yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/preibisch/OpenFOAM/OpenFOAM-1.7.x yes yes yes
$FOAM_APPBIN ...7.x/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_SITE_APPBIN ...nFOAM/site/1.7.x/bin/linux64GccDPOpt no no
$FOAM_USER_APPBIN ...7.x/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR ...ibisch/OpenFOAM/OpenFOAM-1.7.x/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...M/OpenFOAM-1.7.x/lib/linux64GccDPOpt yes yes yes
$FOAM_SITE_LIBBIN ...nFOAM/site/1.7.x/lib/linux64GccDPOpt no no
$FOAM_USER_LIBBIN .../preibisch-1.7.x/lib/linux64GccDPOpt no no
$MPI_ARCH_PATH ...x/platforms/linux64Gcc/openmpi-1.4.1 yes yes yes
Third party software
Software Version Location
gcc 4.4.1 /usr/bin/gcc
gzip 1.3.12 /usr/bin/gzip
tar 1.21 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /home/preibisch/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
*** The foam installation contains 1 critical error(s)
*** Review the output for warning messages and consult
*** the installation guide for trouble shooting.
done.
Old   December 16, 2010, 02:46
Alberto Passalacqua
What version of SUSE? You can check it with
cat /etc/SuSE-release
Alberto Passalacqua
Old   December 16, 2010, 03:23
Stefan
openSUSE 11.2 (x86_64)
VERSION = 11.2
Old   December 16, 2010, 03:49
Robert Sawko
AlmostSurelyRob will become famous soon enough
Perhpas it's a bit late for a reply but in my case (same system OpenSUSE 11.2 ) installing a package
binutils-dev
helped according to the similar post here
http://ubuntuforums.org/showthread.php?t=390903
And if you pardon the pun it's a bit awkward that under free, open source system a free, open source piece of software complains about the lack of liberty.
AlmostSurelyRob is offline   Reply With Quote
Old   December 16, 2010, 06:30
Retired Super Moderator
Bruno Santos
It's a lesson in itself: although one might be free, one must learn what is liberty, how to get it and how to use it! Although in Linux, all you have to do is type a few commands together and liberty is yours
It's also like knowledge: just because one has access to a library, it does not automatically turn the person into a know-it-all!
Old   December 16, 2010, 09:35
Smile
Stefan
thanks for the help. Now OpenFOAM works!
Next Step Paraview
Old   December 16, 2010, 09:47
Alberto Passalacqua
Yes, but the fact that library was not available by default tells me you did not install the "C++ development" pattern, which should pull it in.
Alberto Passalacqua
cannot find -liberty Aneirin OpenFOAM Bugs 1 December 10, 2010 19:37
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Cannot find liberty %3cIMG SRC%3d%22httpopenfoamcfdonlinecomforumcliparthappygif%22 ALT%3d%22%22 BORDER%3d0%3e panara OpenFOAM Installation 5 August 10, 2007 14:39
