OpenFoam-1.6-ext How to enable MPI in paraview compiling?
Hello Forum!
I've installed OpenFOAM(r) succesfully a few days ago. I want to use the Native Parallel OpenFOAM Reader (http://openfoamwiki.net/index.php/Co...r_for_ParaView). A prerequisite is compile paraview using these settings: BUILD_SHARED_LIBS = ON CMAKE_BUILD_TYPE = Release PARAVIEW_USE_MPI = ON As I saw the standard option for PARAVIEW_USE_MPI is OFF. This is the way I compiled paraview. Which option should I set in order to enable MPI using AllMake.stage4? Thanks in advance Pablo |
same problem
Hello Pablo,
Did you get this problem solved? How did you do it? It would also be helpful if anyone could give more information on how this rpm build process is actaully working (I'm not even able to delete a compiled package and compile it again...) Best regards, -Thomas |
Hello Thomas, Sorry for the late reply, I was on vacation! :D Sadly, I could not solve this problem. Regards Pablo |
