OpenFOAM 1.7.1 installation problem on Fedora 14
Hi everyone,
I'm completely new in OpenFOAM, and right now I'm trying to install OpenFOAM 1.7.1 on my laptop which has Fedora 14 as OS. When I run the foamInstallationTest, I get this critical error, it seems unable to find icoFoam: [cooter@annapurna OpenFOAM-1.7.1]$ foamInstallationTest Executing /home/cooter/OpenFOAM/OpenFOAM-1.7.1/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: annapurna OS: Linux version 2.6.35.9-64.fc14.i686.PAE ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/cooter/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/cooter/OpenFOAM/cooter-1.7.1 yes no $WM_THIRD_PARTY_DIR /home/cooter/OpenFOAM/ThirdParty-1.7.1 yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/cooter/OpenFOAM/OpenFOAM-1.7.1 yes yes yes $FOAM_APPBIN ...1.7.1/applications/bin/linuxGccDPOpt no yes $FOAM_SITE_APPBIN ...penFOAM/site/1.7.1/bin/linuxGccDPOpt no no $FOAM_USER_APPBIN ...1.7.1/applications/bin/linuxGccDPOpt no no $WM_DIR ...cooter/OpenFOAM/OpenFOAM-1.7.1/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt yes yes yes $FOAM_SITE_LIBBIN ...penFOAM/site/1.7.1/lib/linuxGccDPOpt no no $FOAM_USER_LIBBIN ...nFOAM/cooter-1.7.1/lib/linuxGccDPOpt no no $MPI_ARCH_PATH ...7.1/platforms/linuxGcc/openmpi-1.4.1 no yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.5.1 /usr/bin/gcc gzip 1.4 /usr/bin/gzip tar 1.23 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/cooter/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. *** The foam installation contains 1 critical error(s) *** Review the output for warning messages and consult *** the installation guide for trouble shooting. done. Any advices will be grateful. Thanks Francesco |
Greetings Francesco and welcome to the Forum!
Well, installing OpenFOAM 1.7.1 in Fedora 14 is pretty much the same as in Fedora 13, so here is some another thread about the same issue: http://www.cfd-online.com/Forums/ope...dora-13-a.html ;) Best regards and good luck! Bruno |
1 Attachment(s)
Thanks Bruno,
As you posted in that previous discussion, I did these two steps. I installed the packages I need with the command: yum install gcc gcc-c++ binutils-devel flex git-core wget cmake qt4-devel python-devel redline-devel bison and then I compiled the software. Unfortunately the errors are still there, when I run the foamInstallationTest. I attached the make.log file, do you have some other advice for me? Thanks a lot. |
Hi Francesco,
I believe you didn't fully read the thread... in the post #8 I mentioned: Quote:
Thank you Bruno,
I read in depth the thread and since I have Fedora i686 i changed the LINEXE line in the file "$WM_DIR/rules/linuxGcc/c++" and so Allwmake was able to compile the OpenFOAM. The foamInstallationTest doesn't return any problems. But unfortunately my troubles aren't terminated :(, and I hope also your words of wisdom! I tried to compile ParaView executing the following: cd $WM_THIRD_PARTY_DIR ./Allclean ./makeParaView and makeParaView returned me this error: ** Error: cannot find qmake either at $QMAKE_PATH or in current $PATH Do you have any further ideas? Thank you very! Francesco |
Hi Francesco,
The quickest solution is to install ParaView 3.8.1 that Fedora 14 has in its repository and then follow point #7 from this blog post: Using the official pre-built ParaView 3.8.0 version with OpenFOAM... This way you can use ParaView's built-in plug-in for reading OpenFOAM's case data format, without the need to spend any more time building ParaView and/or Qt and therefore get to the good stuff of using OpenFOAM :) Best regards and good luck! Bruno |
Great Bruno!
In the end all the things went right. Also paraView works fine. I can't wait to get the good stuff of using OpenFOAM.:D Thanks for all. Francesco |
I am very very new to OpenFOAM. I downloaded OpenFOAM-1.7.1.tar.gz along with the thirdparty.tar.gz . I retrived both files /usr/local/OpenFOAM-1.7.1 dir. The installation instruction say.. to source in my .bashrc file . I hve fedora 13 OS. I am totally confused here how to build up source. Pls pls help me. I am excited to explore its simulation.
OF 1.7.x on the 64 bit Fedora 14
OF 1.7.x on Fedora 14 (64 bit) works perfectly :)
See more info about the subject at http://www.cfd-online.com/Forums/ope...-x86_64-a.html |
Hi Armonica,
How did you test openfoam here. just type foamSystest? pls give details. |
Hi ruma,
To answer some of your questions scattered over several posts and threads: Quote:
foamInstallationTest Quote:
gedit ~/.bashrc Code:
. /opt/openfoam171/etc/bashrc Code:
. ~/.bashrc Quote:
Hi John,
Thnk u very much. Yep, I did run ./Allwmake under $home/OpenFOAM/OpenFOAM-1.7.x/ Checking basic system... ----------------------------------------------------------------------- Shell: /bin/bash Host: guest.saha OS: Linux version 2.6.33.3-85.fc13.x86_64 User: ruma System check: PASS ================== Continue OpenFOAM installation. Step 2: run ./Allwmake . here is the .log file + wmakePrintBuild -check + wmakeLnInclude OpenFOAM + wmakeLnInclude OSspecific/POSIX + Pstream/Allwmake + wmake libso dummy + case "$WM_MPLIB" in + set +x + WM_OPTIONS=linux64GccDPOptOPENMPI + wmake libso mpi OPwrite.C:29:17: error: mpi.h: No such file or directory In file included from OPwrite.C:32: PstreamGlobals.H:55: error: ‘MPI_Request’ was not declared in this scope PstreamGlobals.H:55: error: template argument 1 is invalid PstreamGlobals.H:55: error: invalid type in declaration before ‘;’ token PstreamGlobals.H:56: error: ‘MPI_Request’ was not declared in this scope PstreamGlobals.H:56: error: template argument 1 is invalid PstreamGlobals.H:56: error: invalid type in declaration before ‘;’ token OPwrite.C: In static member function ‘static bool Foam::OPstream::write(Foam::Pstream::commsTypes, int, const char*, std::streamsize)’: OPwrite.C:74: error: ‘MPI_PACKED’ was not declared in this scope OPwrite.C:77: error: ‘MPI_COMM_WORLD’ was not declared in this scope OPwrite.C:78: error: ‘MPI_Bsend’ was not declared in this scope OPwrite.C:86: error: ‘MPI_PACKED’ was not declared in this scope OPwrite.C:89: error: ‘MPI_COMM_WORLD’ was not declared in this scope OPwrite.C:90: error: ‘MPI_Send’ was not declared in this scope OPwrite.C:94: error: ‘MPI_Request’ was not declared in this scope OPwrite.C:94: error: expected ‘;’ before ‘request’ OPwrite.C:100: error: ‘MPI_PACKED’ was not declared in this scope OPwrite.C:103: error: ‘MPI_COMM_WORLD’ was not declared in this scope OPwrite.C:104: error: ‘request’ was not declared in this scope OPwrite.C:105: error: ‘MPI_Isend’ was not declared in this scope OPwrite.C:107: error: request for member ‘append’ in ‘Foam::PstreamGlobals::OPstream_outstandingRequest s_’, which is of non-class type ‘int’ OPwrite.C: In static member function ‘static void Foam::OPstream::waitRequests()’: OPwrite.C:125: error: request for member ‘size’ in ‘Foam::PstreamGlobals::OPstream_outstandingRequest s_’, which is of non-class type ‘int’ OPwrite.C:131: error: request for member ‘size’ in ‘Foam::PstreamGlobals::OPstream_outstandingRequest s_’, which is of non-class type ‘int’ OPwrite.C: In static member function ‘static void Foam::OPstream::waitRequests()’: OPwrite.C:125: error: request for member ‘size’ in ‘Foam::PstreamGlobals::OPstream_outstandingRequest s_’, which is of non-class type ‘int’ OPwrite.C:131: error: request for member ‘size’ in ‘Foam::PstreamGlobals::OPstream_outstandingRequest s_’, which is of non-class type ‘int’ OPwrite.C:132: error: request for member ‘begin’ in ‘Foam::PstreamGlobals::OPstream_outstandingRequest s_’, which is of non-class type ‘int’ OPwrite.C:133: error: ‘MPI_STATUSES_IGNORE’ was not declared in this scope OPwrite.C:134: error: ‘MPI_Waitall’ was not declared in this scope OPwrite.C:143: error: request for member ‘clear’ in ‘Foam::PstreamGlobals::OPstream_outstandingRequest s_’, which is of non-class type ‘int’ OPwrite.C: In static member function ‘static bool Foam::OPstream::finishedRequest(Foam::label)’: OPwrite.C:150: error: request for member ‘size’ in ‘Foam::PstreamGlobals::OPstream_outstandingRequest s_’, which is of non-class type ‘int’ OPwrite.C:156: error: request for member ‘size’ in ‘Foam::PstreamGlobals::OPstream_outstandingRequest s_’, which is of non-class type ‘int’ OPwrite.C:166: error: invalid types ‘int[const Foam::label]’ for array subscript OPwrite.C:168: error: ‘MPI_STATUS_IGNORE’ was not declared in this scope OPwrite.C:169: error: ‘MPI_Test’ was not declared in this scope make: *** [Make/linux64GccDPOptOPENMPI/OPwrite.o] Error 1 + wmake libo OSspecific/POSIX + wmake libso OpenFOAM + wmake libso lagrangian/basic __________________________________________________ ____ '[' -d /home/ruma/OpenFOAM/ThirdParty-1.7.x/platforms/linux64Gcc/paraview-3.8.0 -a -r /home/ruma/OpenFOAM/ThirdParty-1.7.x/platforms/linux64Gcc/paraview-3.8.0 ']' + '[' -d /home/ruma/OpenFOAM/ThirdParty-1.7.x/platforms/linux64Gcc/paraview-3.8.0 -a -r /home/ruma/OpenFOAM/ThirdParty-1.7.x/platforms/linux64Gcc/paraview-3.8.0 ']' -------------------------------------------------------------------------------------------------------------------------- I hve also attached make.log.tar file. The last section of ./Allwmake file says Thirdparty shud be kept under $home/OpenFOAM. **** John : Will you pls check this point? and also wmake OpenFOAM uses wmake to perform compilation (building, linking) of its C++ source code into executable code. wmake is called from the Allwmake scripts during the initial build of the complete OpenFOAM project but can be executed directly to update the compilation of any of the OpenFOAM components:
**** After ./Allwmake run ..when I give ./foamInstallationTest ..it gives me error dot files are nt defined. "make.log" 191L, 8946C 1,1 Top |
Hi Ruma,
Installing as root is a bad idea. The result is that your user has no write permission and that the environment variable etc are not sourced. If you're compiling it's better to make a directory called OpenFOAM in your user home, put the OpenFOAM files inside that dir, and add the source line to you user's $HOME/.bashrc. Then, source your bashrc and run Allwmake. |
Problems installing ThirdParty-1.7.1 ON FEDORA
I have succesfully installed openFoam on Fedora 32 bit machine , but when trying to install it on Fedora 14 64 bit computer I faced the problem . First of all I tried to install ThirdParty software and I got the following error message : ======================================== Start ThirdParty Allwmake ======================================== ======================================== Compile specific mpi libraries have OPENMPI shared library ======================================== Build Scotch decomposition library + cd scotch_5.1/src + mkdir -p /home/yurifeld/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt + make scotch (cd libscotch ; make VERSION=\"5.1\" scotch && make install) make[1]: Entering directory `/home/yurifeld/OpenFOAM/ThirdParty-1.7.1/scotch_5.1/src/libscotch' rm -f *~ *.o lib*.so common2* parser_yy.c parser_ly.h parser_ll.c *scotch.h *scotchf.h y.output dummysizes make CC="gcc" CCD="gcc" SCOTCHLIB=scotch \ scotch.h \ scotchf.h \ libscotch.so \ libscotcherr.so \ libscotcherrexit.so make[2]: Entering directory `/home/yurifeld/OpenFOAM/ThirdParty-1.7.1/scotch_5.1/src/libscotch' gcc -O3 -fPIC -DCOMMON_TIMING_OLD -Drestrict=__restrict -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_PTHREAD -DSCOTCH_RENAME -DSCOTCH_VERSION=\""5.1"\" dummysizes.c -o dummysizes -lz -lm -lrt /usr/bin/ld: cannot find -lz collect2: ld returned 1 exit status make[2]: *** [dummysizes] Error 1 make[2]: Leaving directory `/home/yurifeld/OpenFOAM/ThirdParty-1.7.1/scotch_5.1/src/libscotch' make[1]: *** [scotch] Error 2 make[1]: Leaving directory `/home/yurifeld/OpenFOAM/ThirdParty-1.7.1/scotch_5.1/src/libscotch' make: *** [scotch] Error 2 ======================================== Build PTScotch decomposition library (requires MPI) + cd scotch_5.1/src + mkdir -p /home/yurifeld/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/openmpi-1.4.1 + make ptscotch (cd libscotch ; make VERSION=\"5.1\" ptscotch && make ptinstall) make[1]: Entering directory `/home/yurifeld/OpenFOAM/ThirdParty-1.7.1/scotch_5.1/src/libscotch' rm -f *~ *.o lib*.so common2* parser_yy.c parser_ly.h parser_ll.c *scotch.h *scotchf.h y.output dummysizes make CFLAGS="-O3 -fPIC -DCOMMON_TIMING_OLD -Drestrict=__restrict -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_PTHREAD -DSCOTCH_RENAME -DSCOTCH_PTSCOTCH" CC="mpicc" SCOTCHLIB=ptscotch \ scotch.h \ scotchf.h \ libptscotch.so \ libptscotcherr.so \ libptscotcherrexit.so make[2]: Entering directory `/home/yurifeld/OpenFOAM/ThirdParty-1.7.1/scotch_5.1/src/libscotch' mpicc -O3 -fPIC -DCOMMON_TIMING_OLD -Drestrict=__restrict -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_PTHREAD -DSCOTCH_RENAME -DSCOTCH_PTSCOTCH -DSCOTCH_VERSION=\""5.1"\" dummysizes.c -o dummysizes -lz -lm -lrt /usr/bin/ld: cannot find -lz collect2: ld returned 1 exit status make[2]: *** [dummysizes] Error 1 make[2]: Leaving directory `/home/yurifeld/OpenFOAM/ThirdParty-1.7.1/scotch_5.1/src/libscotch' make[1]: *** [ptscotch] Error 2 make[1]: Leaving directory `/home/yurifeld/OpenFOAM/ThirdParty-1.7.1/scotch_5.1/src/libscotch' make: *** [ptscotch] Error 2 ======================================== Build Metis decomposition + cd metis-5.0pre2 + cpMakeFiles metis + set +x cpMakeFiles metis . + wmake libso GKlib '/home/yurifeld/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libGKlib.so' is up to date. + wmake libso libmetis '/home/yurifeld/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libmetis.so' is up to date. ======================================== Build ParMetis decomposition. Requires MPI. + cd ParMetis-3.1 + cpMakeFiles ParMetis + set +x cpMakeFiles ParMetis . + wmake libso METISLib '/home/yurifeld/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/openmpi-1.4.1/libmetis-parmetis.so' is up to date. + wmake libso ParMETISLib '/home/yurifeld/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/openmpi-1.4.1/libparmetis.so' is up to date. ======================================== Build ParMGridGen + cd ParMGridGen-1.0 + cpMakeFiles ParMGridGen + set +x cpMakeFiles ParMGridGen . + wmake libso MGridGen/IMlib '/home/yurifeld/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libIMlib.so' is up to date. + wmake libso MGridGen/Lib '/home/yurifeld/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libMGridGen.so' is up to date. ======================================== Done ThirdParty Allwmake ======================================== So as far as i understand the problem is in installation of Scotch software. Then I figured out that -lz error means tat my zlib libraries are missing. I installed them with yum Loaded plugins: langpacks, presto, refresh-packagekit Adding en_US to language list Setting up Install Process Package matching zlib-1.2.5-2.fc14.x86_64 already installed. Checking for update. Resolving Dependencies --> Running transaction check ---> Package zlib-devel.x86_64 0:1.2.5-2.fc14 set to be installed --> Processing Dependency: zlib = 1.2.5-2.fc14 for package: zlib-devel-1.2.5-2.fc14.x86_64 ---> Package zlib-static.x86_64 0:1.2.5-2.fc14 set to be installed ---> Package zlibrary.x86_64 0:0.12.10-2.fc14.1 set to be installed --> Processing Dependency: liblinebreak.so.2()(64bit) for package: zlibrary-0.12.10-2.fc14.1.x86_64 --> Processing Dependency: libfribidi.so.0()(64bit) for package: zlibrary-0.12.10-2.fc14.1.x86_64 ---> Package zlibrary-devel.x86_64 0:0.12.10-2.fc14.1 set to be installed ---> Package zlibrary-ui-gtk.x86_64 0:0.12.10-2.fc14.1 set to be installed ---> Package zlibrary-ui-qt.x86_64 0:0.12.10-2.fc14.1 set to be installed --> Running transaction check ---> Package fribidi.x86_64 0:0.19.2-2.fc12 set to be installed ---> Package liblinebreak.x86_64 0:2.0-1.fc14 set to be installed ---> Package zlib.i686 0:1.2.5-2.fc14 set to be installed --> Finished Dependency Resolution Dependencies Resolved ================================================== ================================================== ========================== Package Arch Version Repository Size ================================================== ================================================== ========================== Installing: zlib-devel x86_64 1.2.5-2.fc14 fedora 45 k zlib-static x86_64 1.2.5-2.fc14 fedora 56 k zlibrary x86_64 0.12.10-2.fc14.1 fedora 1.1 M zlibrary-devel x86_64 0.12.10-2.fc14.1 fedora 49 k zlibrary-ui-gtk x86_64 0.12.10-2.fc14.1 fedora 73 k zlibrary-ui-qt x86_64 0.12.10-2.fc14.1 fedora 80 k Installing for dependencies: fribidi x86_64 0.19.2-2.fc12 fedora 48 k liblinebreak x86_64 2.0-1.fc14 fedora 19 k zlib i686 1.2.5-2.fc14 fedora 82 k Transaction Summary ================================================== ================================================== ========================== Install 9 Package(s) Total size: 1.5 M Installed size: 4.6 M Is this ok [y/N]: y Downloading Packages: Running rpm_check_debug Running Transaction Test Transaction Check Error: package zlib-1.2.5-3.fc15.x86_64 (which is newer than zlib-1.2.5-2.fc14.i686) is already installed Error Summary ------------- yum install zlib* but still the linking process did not succeed. more over I tried to locate zlib.h file by locate zlib command but also unsuccessfully. Any ideas, I really need your help Yuri |
Hi Yuri,
Maybe ld can't find zlib or the right zlib. Perhaps it helps to add the location of the right zlib to the LD_LIBRARY_PATH variable. For instance, if zlib lives in /usr/lib/libz.so, then you could add something like below to $HOMA/.bashrc and then source your bashrc: Code:
LD_LIBRARY_PATH=/usr/lib/libz.so:$LD_LIBRARY_PATH |
Hi Gijs, I hve small q's. If I dont install under common file system i.e /usr/local/OpenFOAM/... then how other users can use OpenFOAM. if it is only my /home/ dir, then probably only I can run OpenFOAM. I like to keep it under cooom file system . Then in that case, how to set up environment giving path to my .bashrc file What I can do that I add the path of OpenFOAM in my .bashrc file path set up. |
fieldy77, why would you want to do Allmake in ThirdParty? (unless you want to use paraFoam)
I only do Allmake in OpenFOAM1.7.x and all works fine (I use paraview only). Note I tried once to do Allmake without having ThirdParty present in the OF dir, and got lot of errors. So apparently for openfoam to compile, ThirdParty has to be present (likely because of openMPI and other tools, which works fine on mine system). Again, see http://www.cfd-online.com/Forums/ope...tml#post301689 about Fedora 14 64 bit steps for installing OF |
