ParaView for OF-1.6-ext
Old   December 31, 2010, 06:42
Default ParaView for OF-1.6-ext
Chrisi1984 is on a distinguished road
Hallo all,
I have got a problem installing Paraview for OF-1.6-ext.
The installation of the normal OF seemed to had run properly:
Executing ./foamInstallationTest:
Checking basic setup...
Shell: bash
Host: christian-laptop
OS: Linux version 2.6.32-26-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /opt yes yes
$WM_PROJECT_USER_DIR /root/OpenFOAM/root-1.6-ext yes no
$WM_THIRD_PARTY_DIR /opt/OpenFOAM-1.6-ext/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /opt/OpenFOAM-1.6-ext yes yes yes
$FOAM_APPBIN ...ext/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_SITE_APPBIN /opt/site/1.6-ext/bin/linux64GccDPOpt no no
$FOAM_USER_APPBIN ...ext/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR /opt/OpenFOAM-1.6-ext/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OpenFOAM-1.6-ext/lib/linux64GccDPOpt yes yes yes
$FOAM_SITE_LIBBIN /opt/site/1.6-ext/lib/linux64GccDPOpt no no
$FOAM_USER_LIBBIN ...OAM/root-1.6-ext/lib/linux64GccDPOpt yes yes no
$MPI_ARCH_PATH ...nmpi-1.4.3/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.3
User version : 4.4.3
Minimum required: 4.3.1
gcc 4.4.3 /bin/gcc
gzip 1.3.12 /bin/gzip
tar 1.22 /bin/tar
icoFoam 1.6-ext ...nFOAM-1.6-ext/applications/bin/linux64GccDPOpt/icoFoam
Summary
Base configuration ok.
Critical systems ok.
done.
But during compiling ParaView there seems to occur some Problems. Here is an extract of the errors:
/usr/include/bits/string3.h: At top level:
/usr/include/bits/string3.h:56: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/string3.h: In function ‘memmove’:
/usr/include/bits/string3.h:59: error: ‘__len’ undeclared (first use in this function)
/usr/include/bits/string3.h:78: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/string3.h: In function ‘memset’:
/usr/include/bits/string3.h:80: error: ‘__len’ undeclared (first use in this function)
/usr/include/bits/string3.h:91: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/string3.h: In function ‘bcopy’:
/usr/include/bits/string3.h:94: error: ‘__len’ undeclared (first use in this function)
/usr/include/bits/string3.h:98: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/string3.h: In function ‘bzero’:
/usr/include/bits/string3.h:100: error: ‘__len’ undeclared (first use in this function)
/usr/include/bits/string3.h:120: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/string3.h: In function ‘strncpy’:
/usr/include/bits/string3.h:123: error: ‘__len’ undeclared (first use in this function)
/usr/include/bits/string3.h:127: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/string3.h:128: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/string3.h:129: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/string3.h:134: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/string3.h: In function ‘stpncpy’:
/usr/include/bits/string3.h:136: error: ‘size_t’ undeclared (first use in this function)
/usr/include/bits/string3.h:137: error: ‘__n’ undeclared (first use in this function)
/usr/include/bits/string3.h:138: error: too many arguments to function ‘__stpncpy_chk’
/usr/include/bits/string3.h:139: error: too many arguments to function ‘__stpncpy_alias’
/usr/include/bits/string3.h:151: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/string3.h: In function ‘strncat’:
/usr/include/bits/string3.h:154: error: ‘__len’ undeclared (first use in this function)
In file included from /opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/zutil.h:24,
from /opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.h:16,
from /opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:52:
/usr/include/stdlib.h: At top level:
/usr/include/stdlib.h:140: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘__ctype_get_mb_cur_max’
/usr/include/stdlib.h: In function ‘atof’:
/usr/include/stdlib.h:281: error: ‘NULL’ undeclared (first use in this function)
/usr/include/stdlib.h: In function ‘atoi’:
/usr/include/stdlib.h:286: error: ‘NULL’ undeclared (first use in this function)
/usr/include/stdlib.h: In function ‘atol’:
/usr/include/stdlib.h:291: error: ‘NULL’ undeclared (first use in this function)
/usr/include/stdlib.h: In function ‘atoll’:
/usr/include/stdlib.h:300: error: ‘NULL’ undeclared (first use in this function)
/usr/include/stdlib.h:337: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/stdlib.h:367: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/stdlib.h:369: error: nonnull argument with out-of-range operand number (argument 1, operand 4)
/usr/include/stdlib.h:485: error: expected declaration specifiers or ‘...’ before ‘size_t’
In file included from /usr/include/stdlib.h:497,
/usr/include/alloca.h:33: error: expected ‘)’ before ‘__size’
/usr/include/stdlib.h:502: error: expected ‘)’ before ‘__size’
/usr/include/stdlib.h:507: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/stdlib.h:751: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/stdlib.h:752: error: nonnull argument with out-of-range operand number (argument 1, operand 5)
/usr/include/stdlib.h:756: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/stdlib.h:757: error: nonnull argument with out-of-range operand number (argument 1, operand 4)
/usr/include/stdlib.h:834: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/stdlib.h:837: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/stdlib.h:841: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/stdlib.h:845: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/stdlib.h:854: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/stdlib.h:857: error: expected ‘)’ before ‘*’ token
/usr/include/stdlib.h:861: error: expected declaration specifiers or ‘...’ before ‘wchar_t’
/usr/include/stdlib.h:865: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘mbstowcs’
/usr/include/stdlib.h:868: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘wcstombs’
In file included from /usr/include/stdlib.h:949,
/usr/include/bits/stdlib.h:26: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/stdlib.h:30: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/stdlib.h: In function ‘realpath’:
/usr/include/bits/stdlib.h:40: error: ‘size_t’ undeclared (first use in this function)
/usr/include/bits/stdlib.h:46: error: too many arguments to function ‘__realpath_chk’
/usr/include/bits/stdlib.h: At top level:
/usr/include/bits/stdlib.h:53: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/stdlib.h:54: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/stdlib.h:55: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/stdlib.h:58: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/stdlib.h:65: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/stdlib.h: In function ‘ptsname_r’:
/usr/include/bits/stdlib.h:67: error: ‘size_t’ undeclared (first use in this function)
/usr/include/bits/stdlib.h:69: error: ‘__buflen’ undeclared (first use in this function)
/usr/include/bits/stdlib.h:70: error: too many arguments to function ‘__ptsname_r_chk’
/usr/include/bits/stdlib.h:72: error: too many arguments to function ‘__ptsname_r_chk_warn’
/usr/include/bits/stdlib.h:74: error: too many arguments to function ‘__ptsname_r_alias’
/usr/include/bits/stdlib.h:78: error: expected declaration specifiers or ‘...’ before ‘wchar_t’
/usr/include/bits/stdlib.h:78: error: expected declaration specifiers or ‘...’ before ‘size_t’
/usr/include/bits/stdlib.h:80: error: expected declaration specifiers or ‘...’ before ‘wchar_t’
/usr/include/bits/stdlib.h:84: error: expected declaration specifiers or ‘...’ before ‘wchar_t’
/usr/include/bits/stdlib.h: In function ‘wctomb’:
/usr/include/bits/stdlib.h:93: error: ‘size_t’ undeclared (first use in this function)
/usr/include/bits/stdlib.h:94: error: ‘__wchar’ undeclared (first use in this function)
/usr/include/bits/stdlib.h:94: error: too many arguments to function ‘__wctomb_chk’
/usr/include/bits/stdlib.h:95: error: too many arguments to function ‘__wctomb_alias’
/usr/include/bits/stdlib.h:99: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘__mbstowcs_chk’
/usr/include/bits/stdlib.h:102: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘__mbstowcs_alias’
/usr/include/bits/stdlib.h:106: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘__mbstowcs_chk_warn’
/usr/include/bits/stdlib.h:114: error: expected ‘,’ or ‘;’ before ‘mbstowcs’
/usr/include/bits/stdlib.h:131: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘__wcstombs_chk’
/usr/include/bits/stdlib.h:134: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘__wcstombs_alias’
/usr/include/bits/stdlib.h:138: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘__wcstombs_chk_warn’
/usr/include/bits/stdlib.h:145: error: expected ‘,’ or ‘;’ before ‘wcstombs’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c: In function ‘vtk_zlib_deflateInit2_’:
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:293: error: too many arguments to function ‘memset’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c: In function ‘vtk_zlib_deflateSetDictionary’:
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:346: error: too many arguments to function ‘memcpy’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c: In function ‘flush_pending’:
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:547: error: too many arguments to function ‘memcpy’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c: In function ‘vtk_zlib_deflate’:
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:591: error: ‘NULL’ undeclared (first use in this function)
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:824: error: too many arguments to function ‘memset’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c: In function ‘vtk_zlib_deflateCopy’:
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:919: error: too many arguments to function ‘memcpy’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:924: error: too many arguments to function ‘memcpy’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:939: error: too many arguments to function ‘memcpy’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:940: error: too many arguments to function ‘memcpy’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:941: error: too many arguments to function ‘memcpy’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:942: error: too many arguments to function ‘memcpy’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c: In function ‘read_buf’:
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:983: error: too many arguments to function ‘memcpy’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c: In function ‘lm_init’:
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:998: error: too many arguments to function ‘memset’
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c: In function ‘fill_window’:
/opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/Utilities/vtkzlib/deflate.c:1302: error: too many arguments to function ‘memcpy’
make[2]: *** [VTK/Utilities/vtkzlib/CMakeFiles/vtkzlib.dir/deflate.c.o] Fehler 1
make[1]: *** [VTK/Utilities/vtkzlib/CMakeFiles/vtkzlib.dir/all] Fehler 2
make: *** [all] Fehler 2
Fehler: Fehler-Status beim Beenden von /opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.2bAfBv (%build)
Fehler: Öffnen von /opt/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-3.8.1-linux64GccDPOpt.x86_64.rpm fehlgeschlagen: No such file or directory
+ wmakePrintBuild -check
+ wmakeLnInclude OpenFOAM
Attached is the log-file of the hole compilation with "Allwmake"
Can someone help me to get ParaView installed properly?
I still have a valid installation of ParaView 3.8.1 for OF-1.7.1. Can I also uses this with OF-1.6-ext?
If yes, what should be done therefore?
Best regards
Chrisi
Chrisi1984 is offline   Reply With Quote
[General] Paraview nice animation PyGloo ParaView 4 June 7, 2012 12:34
[OpenFOAM] Distributed ParaView and PV3FoamReader micalil ParaView 4 July 1, 2010 05:09
OpenFOAM 1.6 and ThirdParty Software Paraview dunlopjp OpenFOAM Installation 0 February 24, 2010 11:35
Paraview installation troubles jjhall OpenFOAM Installation 3 April 17, 2008 12:59
[OpenFOAM] ParaView patch visualisation error in Development version philippose ParaView 17 March 26, 2007 06:45
