Paraview not found
I have compiled OF1.5-dev and setup Paraview according to the instructions given as below (PhD course - Chalmers). When I want to run it and type paraFoam I get the following message: /OpenFOAM/OpenFOAM-1.5-dev/bin/paraFoam: 105: paraview: not found. Does someone have a solution for this problem? Quote:
Greetings Vigfús,
OK, with the OpenFOAM's 1.5-dev environment up and running, what does this command output: Code:
echo $ParaView_DIR Code:
ls $ParaView_DIR There is also another possibility for installing ParaView for usgin with OpenFOAM, depending on which Linux Distribution and version you are using. For example, if you are using Ubuntu 10.10, you can install ParaView 3.8.1 that is available from Ubuntu's repositories: Code:
sudo apt-get install paraview Bruno PS: Wow, this is so cool :) A blog post of mine is being referenced at Chalmers, Dept of Thermo and Fluid Dynamics :D |
Problem is solved. The precompiled ParaView3.8 directory created was named ParaView3.3-cvs. But since ParaView_INST_DIR=$WM_THIRD_PARTY_DIR/ParaView-$ParaView_VERSION
or more specifically ParaView-3.3-cvs had nothing in it unless the linux64Gcc directory, I just moved the files under that directory in ParaView3.3-cvs to the ParaView-3.3-cvs directory. And now it works. I am not sure why there are two folders, but I followed the tutorial step by step. Thank you Bruno for your quick answer. |
