Error in ThirdParty compilation of OpenFoam-16-ext...rpm:command not found
Old   January 7, 2011, 23:18
Default Error in ThirdParty compilation of OpenFoam-16-ext...rpm:command not found
Arvind
arvind_arya is on a distinguished road
I trying to compile OpenFoam-1.6-ext with ubuntu-10.04 but when i try to run ./AllMake in thirdparty it start printing the following:
tools/makeThirdPartyFunctionsForRPM: line 34: rpm: command not found
Kindly suggest the remedy for this!!! i have searched the forum but could not get same error reported by others. i feel some new package i have t install???
Thanks
arvind_arya is offline   Reply With Quote
Old   January 9, 2011, 00:45
David Boger
boger is on a distinguished road
You need the rpm package, but there's other related discussion here.
David A. Boger
boger is offline   Reply With Quote
Old   January 9, 2011, 10:25
Arvind
Thank you very much boger ....i am trying with mentioned tips..
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Compilation Error.... Arnab Siemens 4 September 12, 2004 15:54
