building MRFSimpleFoam
Hi everybody.
I continue here another thread because a user defined my problem, so this is the right forum section. I installed OpenFOAM-1.5-dev from CAE Team PPA and I want to use MRFSimpleFoam. I was explained I have to build it into MRFSimpleFoam tutorial folder. I found /usr/share/doc/openfoam-dev-1.5/examples/MRFSimpleFoam/MRFSimpleFoam. It contains a subdirectory Make (with files and options files) and two files: MRFSimpleFoam.C and createFields.H. I tried wmake but it fails (not found). Maybe I have to run make? I use Ubuntu 10.04 64-bit. |
Hi Maurizio,
Here's what you do: Code:
mkdir -p $WM_PROJECT_USER_DIR Code:
sudo apt-get install openfoam-dev-1.5-dev Bruno |
Thank you, Bruno. You're always helpful.
