Qt version of Paraview 3.8.0 in OpenFOAM 1.7
Old   August 5, 2010, 13:09
Default Qt version of Paraview 3.8.0 in OpenFOAM 1.7
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Hi everyone
It seems that by using makeParaview tool in the ThirdParty package I can build the paraview 3.8.0 within the ThirdPary package. but with the same machine I can not build the paraview 3.8.0 manual by using ccmake to configure and generate. It error message in ccmake is :
CMake Error at CMakeLists.txt:88 (MESSAGE):
Qt 4.5.0 or greater not found. Please check the QT_QMAKE_EXECUTABLE
variable.
CMake Error at VTK/CMakeLists.txt:310 (MESSAGE):
variable.
Qt QTGUI library not found.
Qt QTSQL library not found.
Qt QTCORE library not found.
that`s Why?
another quiestion is that if anybody have succeed in building OSMesa in RHEL 4? when i built that , I got all share lib by libGL.so and glx can`t build successful with error message:
../../../bin/mklib -o GL -linker 'gcc' \
-major 1 -minor 2 \
-install ../../../lib -lX11 -lXext -lm -lpthread glcontextmodes.o clientattrib.o compsize.o eval.o glxcmds.o glxext.o glxextensions.o indirect.o indirect_init.o indirect_size.o indirect_window_pos.o indirect_transpose_matrix.o indirect_vertex_array.o indirect_vertex_program.o pixel.o pixelstore.o render2.o renderpix.o single2.o singlepix.o vertarr.o xfont.o glx_pbuffer.o glx_query.o glx_texture_compression.o dri_glx.o XF86dri.o ../../../src/mesa/main/dispatch.o ../../../src/mesa/glapi/glapi.o ../../../src/mesa/glapi/glthread.o
mklib: Making Linux shared library: libGL.so.1.2
../../../src/mesa/main/dispatch.o: In function `gl_dispatch_stub_366':
dispatch.c.text+0xdb10): multiple definition of `gl_dispatch_stub_366'
indirect.o:indirect.c.text+0xea10): first defined here
/usr/bin/ld: Warning: size of symbol `gl_dispatch_stub_366' changed from 205 in indirect.o to 85 in ../../../src/mesa/main/dispatch.o
`glAreTexturesResidentEXT':
dispatch.c.text+0x103d0): multiple definition of `glAreTexturesResidentEXT'
indirect.o:indirect.c.text+0xf730): first defined here
/usr/bin/ld: Warning: size of symbol `glAreTexturesResidentEXT' changed from 293 in indirect.o to 87 in ../../../src/mesa/main/dispatch.o
collect2: ld returned 1 exit status
mklib: Installing libGL.so.1.2 libGL.so.1 libGL.so in ../../../lib
mv: cannot stat `libGL.so.1.2': No such file or directory
make: *** [../../../lib/libGL.so] Error 1
is there anyone can help ?
thanks
waynezw0618 is offline   Reply With Quote
Old   August 7, 2010, 18:16
Retired Super Moderator
Bruno Santos
Greetings Wayne Zhang,
variable.
that`s Why?
You need to install Qt 4.5 or Qt 4.6, including Qt's development tools. And since you seem to be using RHEL 4, you probably better build Qt from source. You can check my signature link at the end of this post for more possible solutions for you ParaView+Qt problems.
As for OSMesa+RHEL4, I'm all out of ideas, since I've rarely managed to build it successfully in Ubuntu and Windows, and I have no experience with RHEL
Best regards,
Bruno
Old   August 8, 2010, 14:07
wayne.zhang
Hi
Thanks for you reply. I have rebuilt the Qt with -no-openssl and then resolve the first problem.
But for the last , I still can`t not make the osmesa correctly in redhat, but fine in Opensuse, osmesa is very usefull of off screen rendering. it is needed to built paraview with tool pvbatch.
wayne
Old   August 9, 2010, 03:20
Gijsbert Wierink
gwierink is on a distinguished road
Hi Wayne,
I have no experience with Red Hat itself, but in Fedora and Scientific Linux (both Red Hat based) yum finds libosmesa:
[root@pc7368 wierink_g]# yum search libosmesa
Loaded plugins: kernel-module
sl5base                   100% |=========================| 1.1 kB    00:00
sl5kernel                 100% |=========================|  951 B    00:00
sl5nonfree                100% |=========================|  951 B    00:00
sl5others                 100% |=========================|  951 B    00:00
sl5psi                    100% |=========================|  951 B    00:00
sl5update                 100% |=========================|  951 B    00:00
============================== Matched: libosmesa ==============================
mesa-libOSMesa.i386 : Mesa offscreen rendering libraries
mesa-libOSMesa.x86_64 : Mesa offscreen rendering libraries
mesa-libOSMesa-devel.i386 : Mesa offscreen rendering development package
mesa-libOSMesa-devel.x86_64 : Mesa offscreen rendering development package
Have you searched with yum for libosmesa and tried to install it? I guess it would be good to install libosmesa and libosmesa-devel.
Regards, Gijs
gwierink is offline   Reply With Quote
Old   August 9, 2010, 11:41
wayne.zhang
Hi
Thanks, I am user of machine but NOT root.
but I have resolve the problem
Thanks
It works fine right now.
pvbatch --use-offscreen-rendering mypythonsrcipt.py
Old   March 3, 2011, 04:19
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Hi Foamers,
I'm trying to install OF 1.7.x with Paraview 3.8.0 on a Suse Linux Enterprise Server 11 SP 1, that has as default QT 4.4.
I have problems as there aren't packages of QT 4.5.x or higher for this Distro (damned commercial distros!!!), and I don't know how to compile and install a correct version of QT in my system to be used by OF and Paraview only.
Could anyone give me some help?
Thanks, Ivan
ivan_cozza is offline   Reply With Quote
Old   March 3, 2011, 04:40
Gijsbert Wierink
Hi Ivan,
Can you compile QT from source?
wget ftp://ftp.trolltech.no/qt/source/qt-x11-opensource-src-4.5.3.tar.gz
Regards, Gijs
Old   March 3, 2011, 05:00
Ivan Flaminio Cozza
Originally Posted by gwierink View Post
Hi Ivan,
Hi gwierink,
I've already downloaded a QT 4.6.3 source pack, but I've not allready compiled it. The question is, how can I use this version without overriding the system version and how can I tell OF to use this version and not the system one?
Thanks,
Ivan
Old   March 3, 2011, 05:15
Gijsbert Wierink
Hi Ivan,
Have a look at this page, in particular the section below:
Now we also have to install Paraview 3.8.0 and the PV3FoamReader module, which requires qt to be installed: cd $HOME/OpenFOAM/ThirdParty-1.7.x
mkdir qt-everywhere-opensource-src-4.6.3
mkdir linuxSrc; cd linuxSrc
wget http://get.qt.nokia.com/qt/source/qt...c-4.6.3.tar.gz
tar xzf qt-everywhere-opensource-src-4.6.3.tar.gz
cd qt-everywhere-opensource-src-4.6.3
./configure -prefix $HOME/OpenFOAM/ThirdParty-1.7.x/qt-everywhere-opensource-src-4.6.3 -opensource -stl 2>&1 | tee log_configure
(-stl might be needed for the GUI. It SHOULD have been activated by default, but there is a problem)
#(choose OpenSource editon and accept conditions)
make 2>&1 | tee log_make #Check this file for error messages! This takes several hours!
make install 2>&1 | tee log_make_install #Check this file for error messages!
Add the following to the end of your $HOME/OpenFOAM/OpenFOAM-1.7.x/etc/apps/paraview3/bashrc file:
export PATH=$WM_THIRD_PARTY_DIR/qt-everywhere-opensource-src-4.6.3/bin:$PATH
export LD_LIBRARY_PATH=$WM_THIRD_PARTY_DIR/qt-everywhere-opensource-src-4.6.3/lib:$LD_LIBRARY_PATH
Regards, Gijs
Old   March 3, 2011, 06:38
Bruno Santos
Greetings to all!
Here's another tutorial on how to build ParaView 3.8.0 with a custom Qt 4.6: Building ParaView 3.8.0 with custom Qt 4.6.3
Best regards,
Bruno
Old   March 3, 2011, 08:53
Ivan Flaminio Cozza
Hi Ivan,
Thank you gwierink, it worked perfectly!
OpenFOAM on cluster: version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found ovie OpenFOAM 10 April 19, 2021 18:06
[OpenFOAM] Problem with paraFoam on a linux-64 bit bunni ParaView 4 April 14, 2010 20:55
OpenFOAM Version 1.1 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 11, 2005 05:33
OpenFOAM Version 1.0.2 Released Admin (Admin) OpenFOAM Announcements from ESI-OpenCFD 0 January 12, 2005 06:33
OpenFOAM Version 1.0 Released Admin (Admin) OpenFOAM Announcements from ESI-OpenCFD 0 December 14, 2004 10:58
