Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? |
March 8, 2011, 03:19 |
sirLentschi
I am an absolute Newbie on Linux but I set up OF-1.6-ext on OpenSuse 11.2 and it works fine! Now I want to "install" ParaView 3.81 separately but have no idea to perform this. I downloaded it from : http://www.paraview.org/paraview/res.../software.html Now I have a paraview directory with some executables,which I can start by clicking. But if I want to start paraFoam in my case-dir,then I get this error: /home/lenama/OpenFOAM/OpenFOAM-1.6-ext/bin/paraFoam: line 100: paraview: command not found Here is my paraFoam-file: #!/bin/sh #------------------------------------------------------------------------------ # ========= | # \\ / F ield | OpenFOAM: The Open Source CFD Toolbox # \\ / O peration | # \\ / A nd | Copyright held by original author # \\/ M anipulation | #------------------------------------------------------------------------------- # License # This file is part of OpenFOAM. # # OpenFOAM is free software; you can redistribute it and/or modify it # under the terms of the GNU General Public License as published by the # Free Software Foundation; either version 2 of the License, or (at your # option) any later version. # # OpenFOAM is distributed in the hope that it will be useful, but WITHOUT # ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or # FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License # for more details. # # You should have received a copy of the GNU General Public License # along with OpenFOAM; if not, write to the Free Software Foundation, # Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA # # Script # paraFoam # # Description # start paraview with the OpenFOAM libraries # #------------------------------------------------------------------------------ Script=${0##*/} usage() { while [ "$#" -ge 1 ]; do echo "$1"; shift; done cat<<USAGE usage: $Script [-case dir] * start paraview $ParaView_VERSION with the OpenFOAM libraries USAGE exit 1 } # parse options if [ "$#" -gt 0 ]; then case "$1" in -h | -help) usage ;; -case) shift caseDir=$1 [ "$#" -ge 1 ] || usage "'-case' option requires an argument" cd "$caseDir" 2>/dev/null || usage "directory does not exist: '$caseDir'" ;; *) usage "unknown option/argument: '$*'" ;; esac fi # get a sensible caseName caseName=${PWD##*/} # parent directory for normal or parallel results case "$caseName" in processor*) parentDir=".." ;; *) parentDir="." ;; esac # check existence of essential files for check in system/controlDict system/fvSchemes system/fvSolution do [ -s "$parentDir/$check" ] || usage "file does not exist: '$parentDir/$check'" done #caseFile="$caseName.foam" caseFile="$caseName.OpenFOAM" case "$ParaView_VERSION" in 2*) # Clean up on termination and on Ctrl-C trap "rm -f paraFoam.pvs $caseFile 2>/dev/null; exit 0" EXIT TERM INT touch $caseFile # since we are now in the cwd, %CASE% is '$PWD/$caseFile' sed -e s%CASE%$PWD/$caseFile%g \ $WM_PROJECT_DIR/bin/paraFoam.pvs > paraFoam.pvs paraview paraFoam.pvs ;; *) # Clean up on termination and on Ctrl-C trap "rm -f $caseFile 2>/dev/null; exit 0" EXIT TERM INT touch $caseFile paraview --data=$caseFile ;; esac #------------------------------------------------------------------------------ If I type "paraview" in the case-dir, I get this error: If 'paraview' is not a typo you can use command-not-found to lookup the package that contains it, like this: cnf paraview There must be a problem with the command "paraview" because the system cannot find it. Has anyone a idea to solve my problem? Thanks in advance. Regards Markus Last edited by lentschi; March 8, 2011 at 05:47. |
March 9, 2011, 02:32 |
sirLentschi
I got it!
I just forgot to set the PATH of ParaView in the bashrc - file! |
install OpenFoam 1.6 by building source: how? | niudie | OpenFOAM Installation | 13 | April 26, 2011 00:48 |
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 | aero_ | ParaView | 14 | August 2, 2010 18:13 |
How to install ParaView-3.6.1 in OpenFOAM-1.5-dev and OpenSuse 11.2 | pcaron | OpenFOAM | 0 | April 7, 2010 11:06 |
OpenFOAM 1.6 and ThirdParty Software Paraview | dunlopjp | OpenFOAM Installation | 0 | February 24, 2010 11:35 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
