problem with libmpi.so.0
Hi there
i'm a newbie in linux/openfoam and i have this problem: i installed openfoam on my notebook (opensuse 11.3 32bit) following the instructions. it seemed all to be correct and then i ran the cavity example. blockmesh, icofoam worked and paraview started but it stuck. i waited for 5 minutes but nothing happened i had no control over the machine. i pressed the off button and when i rebooted and tried to run the cavity example again i took the message by blockmesh: blockMesh: error while loading shared libraries: libmpi.so.0: cannot open shared object file: No such file or directory i checked in yast the mpi lib and found out that libmpi.so.0 exists on the system. i tried other examples but took the same message. can anybody help me? |
ok the problem is solved. although i dont understand how...
i just ran the failsafe mode of suse and by rebooting everything worked. |
