Home > Forums > OpenFOAM Installation
OpenFOAM-1.6-ext Compilation Error
Old   May 6, 2011, 08:09
Default OpenFOAM-1.6-ext Compilation Error
taner is on a distinguished road
Dear all,
I've just installed OpenFOAM-1.6-ext on Ubuntu Maverick in order to test GGI for a case. I've modified the .bashrc file like:
#. /opt/openfoam171/etc/bashrc
. /usr/lib/OpenFOAM-1.6-ext/etc/bashrc
The SimpleFOAM solver is working, since the binary is available.
Trying to compile the MRFSimpleFoam solver, I got the following error:
SOURCE=MRFSimpleFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/usr/lib/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/turbulenceModels -I/usr/lib/OpenFOAM-1.6-ext/src/transportModels -IlnInclude -I. -I/usr/lib/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/MRFSimpleFoam.o
MRFSimpleFoam.C:34: fatal error: fvCFD.H: No such file or directory
compilation terminated.
make: *** [Make/linux64GccDPOpt/MRFSimpleFoam.o] Error 1
Does anybody have an idea what the problem is?
Why fvCFD.H cannot be found?
Something to do with environmental variables?
Thanks in advance.
Taner
taner is offline   Reply With Quote
Old   May 6, 2011, 09:22
lazio
lrunber is on a distinguished road
Hi Taner,
You should also install the:
openfoam-1.6-ext-dev
package, which contains the source files.
lrunber is offline   Reply With Quote
Old   May 6, 2011, 10:21
Hi lrunber,
perfect! Installing openfoam-1.6-ext-dev solved the problem.
Thanks a lot.
Taner
Old   May 6, 2011, 10:37
lazio
happy to have been able to help
Old   April 2, 2012, 12:36
nadine moussa
nadine is on a distinguished road
I am having the same error, but I am using Fedora 15. and I installed a fedora package from the OpenFoam site, so am I missing some libraries or something?
my exact error is : "C:33:19: fatal error: fvCFD.H: No such file or directory"
Thanks for your help,
Nadine
nadine is offline   Reply With Quote
Old   April 3, 2012, 06:01
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Nadine,
I'm sorry to say that your post isn't making much sense Because:
  1. You've posted on a thread for 1.6-ext, which is a variant of OpenFOAM, i.e., it is not the official version.
  2. You're talking about installing a "fedora package", which should imply that you don't need to compiled anything: http://www.openfoam.org/download/fedora.php
  3. The error you're getting implies that you are trying to compile OpenFOAM on Fedora!
  4. How exactly did you get that error?
My guess is that you are following the wrong instructions... you're probably looking for either one of these instructions:
Best regards,
Bruno
Old   April 3, 2012, 10:28
nadine moussa
Hello Bruno,
Thank you for answering me in such a short time. I think I installed Openfoam correctly, so my problem isn't an installation problem.
I was trying some features of Openfoam, so I create a new simple solver, and according to the instructions I have to compile it in order to use it, and that's how I got this error saying that fvCFD.H doesn't exsist while it does!!! and my solver can't be compiled!
for informations: my solver call this finite volume libary.
Thanks again for your help
Best regards,
Nadine
Old   April 3, 2012, 21:04
Bruno Santos
Hi Nadine,
Without you describing what specific steps you are taking to create said new solver... I'm going to suggest that you follow this tutorial instead: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
If you still have problems with this one, then it would also be useful to know if your Fedora 15 installation has been done with i686 or x86_64:
uname -m
Best regards,
Bruno
Old   April 4, 2012, 09:51
nadine moussa
Hello Bruno,
I am really grateful for your continuous help!
Actually what I call a new solver was really similar to the example that you sent me but with other instructions. So by following the Wiki instructions I didn't get any error, than I tried their way for adding my solver and it worked! Now I am not getting any error any more, but I tried to find what was missing in the first method but I didn't succeed
Anyway to answer your question I installed OpenFoam-2.1.0 for 64 bits!
Thanks again for your Help!
Best regards,
Nadine
Thread Tools
Trackbacks are On
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
