Setting path to applications?
Old   May 22, 2011, 06:03
Default Setting path to applications?
Anne Wijbenga
annewijbenga is on a distinguished road
I am using ubuntu 10.4 LTS and installation upto showing the usage message after "icoFoam -help" was no problem.
I also copied the tutorials to my directory, so far so good.
I continued with getting started and tried to start blockMesh, but I get the following message:
blockMesh: command not found
I verified that the program is available. I assume that i have to add some information somewhere to let my system look for it in the right place. I presume it is more of a linux problem than a OpenFoam problem. I am however not that smart (yet) with linux.
Has somebody a clue?
Thanks A
annewijbenga is offline   Reply With Quote
Old   May 22, 2011, 06:25
Retired Super Moderator
Bruno Santos
Greetings Anne and welcome to the forum!
Did you do everything in the same terminal window?
When you ran 'blockMesh', did you try 'icoFoam -help' again?
Did you read the (foot)notes in the instructions?
Try starting a new terminal window/tab. Then run 'icoFoam -help' again. If it doesn't find it, then edit once again your "~/.bashrc" file and check if it looks like how the instructions told you to do.
If all OK, then try again following the "Getting Started" instructions!
Best regards,
Bruno
Old   May 22, 2011, 06:42
Anne Wijbenga
No, I didnot. For the test icoFoam, I opened a new terminal.
I have now run: $HOME/.bashrc and it looks OK now. I guess I missed one of the footnotes. Thanks for helping me out.
A
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Warning 097- AB Siemens 6 November 15, 2004 04:41
