OpenFoam 1.6-ext - Install error
Old   June 8, 2011, 07:31
Default OpenFoam 1.6-ext - Install error
Stefan
preibie is on a distinguished road
I want to install OpenFOAM on Suse Enterprise 11. I started with ThirdParty stage 0 and all is OK. Stage 1 shows me the following message:
This system rpm command: rpm
Starting ThirdParty AllMake: Stage1
Updating the ThirdParty environment variables before building package cmake-2.8.3
Making package cmake-2.8.3 using RPM.
Building package cmake-2.8.3
Executing(%prep): /bin/sh -e /home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.57823
Executing(%build): /bin/sh -e /home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.57823
CMake 2.8.3, Copyright 2000-2009 Kitware, Inc.
C compiler on this system is: gcc -m64 -fPIC
Error when bootstrapping CMake:
Cannot find appropriate C++ compiler on this system.
Please specify one using environment variable CXX.
See cmake_bootstrap.log for compilers attempted.
Log of errors: /home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Bootstrap.cmk/cmake_bootstrap.log
RPM build errors:
Installing package: cmake-2.8.3
  Uninstalling cmake-2.8.3 using RPM: cmake-2.8.3-linux64GccDPOpt.x86_64
  Installing cmake-2.8.3 using RPM file: /home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/cmake-2.8.3-linux64GccDPOpt.x86_64.rpm
Done installing package cmake-2.8.3
Done ThirdParty AllMake: Stage1
gcc is installed!
thanks for your help
Preibie
preibie is offline   Reply With Quote
Old   June 8, 2011, 09:52
Martin Beaudoin
mbeaudoin will become famous soon enough
This message should ring a bell:
Basically, you have gcc installed, but not g++, the GNU C++ compiler.
On OpenSUSE 11, the GNU g++ compiler is made available from a different RPM than the gcc compiler.
This is probably similar for SuSE Enterprise 11
Martin
RPM build errors:
gcc is installed!
Preibie
mbeaudoin is offline   Reply With Quote
Old   June 8, 2011, 10:39
Stefan
now the bell is ringing!
you are right I installed g++
Old   June 9, 2011, 11:52
gtg258f is on a distinguished road
I am trying to install OpenFoam-1.6-ext on a Mac. I found quite a few useful links, but am stuck with the following error:
When doing Allmake in Thirdparty, libccmio-2.6.1 does not compile properly.
All the rest went fine (stages 0, 1, 2, 4 and the rest of stage 3)
I think the source of my problem is given by the following line:
+ make -f Makefile.qmake all
           ..//config/runqmake ../ \
                -o Makefile.adf adf.pro 2>&1 | tee qmake.vars
           System type i386-apple-darwin10.7.0 not supported
(As you may guess my system is: Darwin Kernel Version 10.7.0 i386)
The error then keeps repeating (I am attaching the screen output in case it may be more helpful).
What does that exactly mean? Should I download another version of libccmio?
Also ... once I resolve the issue of libccmio, should I clean all and re-make?
Thank you in advance!
gtg258f is offline   Reply With Quote
Old   June 9, 2011, 17:22
Martin Beaudoin
The fix to your problem is available under the branch "hotfix/ThirdParty_scripts" on the git repo for 1.6-ext.
May I recommend you report such problem for 1.6-ext using the Bug Tracking system for OF-1.6-ext?
https://sourceforge.net/apps/mantisb..._view_page.php
The Forum is not such a great place for bug reports.
I personally do not take the time to read every messages on the Forum, but every time you log in a bug report over the Bug tracking system for 1.6-ext, many developers (myself included) will receive a nice Email notification. This is much more efficient.
Still no guarantee your bug will get fixed quickly enough for you, but at least, your bug report might not get lost in the 100s of messages posted every week on the OpenFOAM Forum.
Martin
Old   April 10, 2012, 11:42
Default Similar error
Timo K.
timo_IHS is on a distinguished road
I also have a problem to compile cmake on a Cray machine. Has anybody an idea? I use CC-compiler. The error is in ThirdParty/AllMake.stage1:
Using Cray XT compiler drivers
Executing(%prep): /bin/sh -e /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/tmp/rpm-tmp.73473
Executing(%build): /bin/sh -e /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/tmp/rpm-tmp.12336
C compiler on this system is: cc -fPIC
C++ compiler on this system is: CC -fPIC
Makefile processor on this system is: gmake
CC is GNU compiler
CC has STL in std:: namespace
CC has ANSI streams
CC has streams in std:: namespace
CC has sstream
CC has operator!=(string, char*)
CC has stl iterator_traits
CC has standard template allocator
CC has allocator<>::rebind<>
CC does not have non-standard allocator<>::max_size argument
CC has stl containers supporting allocator objects
CC has header cstddef
CC requires template friends to use <>
CC supports member templates
CC has standard template specialization syntax
CC has argument dependent lookup
CC has struct stat with st_mtim member
CC has ios::binary openmode
CC has ANSI for scoping
CC -fPIC -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Bootstrap.cmk -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Source -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Bootstrap.cmk -c /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Source/cmStandardIncludes.cxx -o cmStandardIncludes.o
CC -fPIC -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Bootstrap.cmk -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Source -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Bootstrap.cmk -c /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Source/cmake.cxx -o cmake.o
cc -fPIC -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Bootstrap.cmk -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Source -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Bootstrap.cmk -DKWSYS_NAMESPACE=cmsys -DKWSYS_STRING_C -c /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Source/kwsys/String.c -o String.o
cc -fPIC -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Bootstrap.cmk -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Source -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Bootstrap.cmk -DKWSYS_NAMESPACE=cmsys -c /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Source/kwsys/System.c -o System.o
CC -fPIC -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Bootstrap.cmk -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Source -I/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/cmake-2.8.3/Bootstrap.cmk cmStandardIncludes.o cmake.o cmakemain.o cmakewizard.o cmCommandArgumentLexer.o cmCommandArgumentParser.o cmCommandArgumentParserHelper.o cmDefinitions.o cmDepends.o cmDependsC.o cmDocumentationFormatter.o cmDocumentationFormatterText.o cmPolicies.o cmProperty.o cmPropertyMap.o cmPropertyDefinition.o cmPropertyDefinitionMap.o cmMakeDepend.o cmMakefile.o cmExportFileGenerator.o cmExportInstallFileGenerator.o cmInstallDirectoryGenerator.o cmGeneratedFileStream.o cmGeneratorExpression.o cmGlobalGenerator.o cmLocalGenerator.o cmInstallGenerator.o cmInstallExportGenerator.o cmInstallFilesGenerator.o cmInstallScriptGenerator.o cmInstallTargetGenerator.o cmScriptGenerator.o cmSourceFile.o cmSourceFileLocation.o cmSystemTools.o cmTestGenerator.o cmVersion.o cmFileTimeComparison.o cmGlobalUnixMakefileGenerator3.o cmLocalUnixMakefileGenerator3.o cmMakefileExecutableTargetGenerator.o cmMakefileLibraryTargetGenerator.o cmMakefileTargetGenerator.o cmMakefileUtilityTargetGenerator.o cmBootstrapCommands.o cmCommands.o cmTarget.o cmTest.o cmCustomCommand.o cmDocumentVariables.o cmCacheManager.o cmListFileCache.o cmComputeLinkDepends.o cmComputeLinkInformation.o cmOrderDirectories.o cmComputeTargetDepends.o cmComputeComponentGraph.o cmExprLexer.o cmExprParser.o cmExprParserHelper.o cmListFileLexer.o Directory.o Glob.o RegularExpression.o SystemTools.o ProcessUNIX.o String.o System.o -o cmake
Problem while running initial CMake
RPM build errors:
Uninstalling cmake-2.8.3 using RPM: cmake-2.8.3-crayxeGccDPOpt.x86_64
Installing cmake-2.8.3 using RPM file: /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/RPMS/x86_64/cmake-2.8.3-crayxeGccDPOpt.x86_64.rpm
timo_IHS is offline   Reply With Quote
Old   May 10, 2012, 03:16
Timo K.
Hello everybody,
I'm still trying to compile ThirdParty, with gcc.4.6.3 and I want to use CC-Compiler. In stage 3 I have problems with Mesquite and Scotch. Has anybody an idea to fix this problem?
Best,
Timo
+ umask 022
+ cd /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD
+ rm -rf mesquite-2.1.2
+ /usr/bin/gzip -dc /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/SOURCES/mesquite-2.1.2.tar.gz
+ tar -xf -
+ STATUS=0
+ '[' 0 -ne 0 ']'
+ cd mesquite-2.1.2
++ /usr/bin/id -u
+ '[' 28938 = 0 ']'
++ /usr/bin/id -u
+ '[' 28938 = 0 ']'
+ /bin/chmod -Rf a+rX,u+w,g-w,o-w .
+ exit 0
+ umask 022
+ /bin/rm -rf /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/mesquite-2.1.2-root
++ dirname /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/mesquite-2.1.2-root
+ /bin/mkdir -p /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD
+ /bin/mkdir /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/mesquite-2.1.2-root
+ cd mesquite-2.1.2
+ '[' -n cc ']'
+ export CC=cc
+ CC=cc
+ '[' -n CC ']'
+ export CXX=CC
+ CXX=CC
+ '[' -n -fPIC ']'
+ export CFLAGS=-fPIC
+ CFLAGS=-fPIC
+ '[' -n -fPIC ']'
+ export CXXFLAGS=-fPIC
+ CXXFLAGS=-fPIC
+ '[' -n '' ']'
+ ./configure --prefix=/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/packages/mesquite-2.1.2/platforms/crayxeGccDPOpt --enable-release --disable-debug-assertions --disable-igeom --disable-imesh --disable-irel --enable-shared --without-cppunit --enable-trap-fpe --disable-function-timers
configure: error: in `/zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/mesquite-2.1.2':
configure: error: cannot run C compiled programs.
If you meant to cross compile, use `--host'.
See `config.log' for more details.
error: Bad exit status from /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/tmp/rpm-tmp.98179 (%build)
error: open of /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/RPMS/x86_64/mesquite-2.1.2-crayxeGccDPOpt.x86_64.rpm failed: No such file or directory
+ umask 022
+ rm -rf scotch_5.1.10b
+ /usr/bin/gzip -dc /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/SOURCES/scotch-5.1.10b.tar.gz
+ tar -xf -
+ STATUS=0
+ '[' 0 -ne 0 ']'
+ cd scotch_5.1.10b
++ /usr/bin/id -u
+ '[' 28938 = 0 ']'
++ /usr/bin/id -u
+ '[' 28938 = 0 ']'
+ echo 'Patch #0 (scotch-5.1.10b_patch_0):'
+ patch -p1 --fuzz=0 -s
+ exit 0
+ umask 022
+ /bin/rm -rf /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/scotch-5.1.10b-root
++ dirname /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/scotch-5.1.10b-root
+ /bin/mkdir /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/BUILD/scotch-5.1.10b-root
+ cd scotch_5.1.10b
+ '[' -n cc ']'
+ export CC=cc
+ CC=cc
+ '[' -n CC ']'
+ export CXX=CC
+ CXX=CC
+ '[' -n -fPIC ']'
+ CFLAGS=-fPIC
+ '[' -n -fPIC ']'
+ CXXFLAGS=-fPIC
+ '[' -n '' ']'
+ cd src
+ ln -s Make.inc/Makefile.inc.crayxe Makefile.inc
+ '[' -z 2 ']'
+ make -j 2 scotch
./dummysizes: error while loading shared libraries: libscicpp_gnu.so.1: cannot open shared object file: No such file or directory
make[2]: *** [scotch.h] Error 127
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [scotch] Error 2
make: *** [scotch] Error 2
error: Bad exit status from /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/tmp/rpm-tmp.89659 (%build)
error: open of /zhome/academic/HLRS/ihs/ihstimok/OpenFOAM/OpenFOAM-1.6-ext/OpenFOAM-1.6-ext-ESM/ThirdParty/rpmBuild/RPMS/x86_64/scotch-5.1.10b-crayxeGccDPOpt.x86_64.rpm failed: No such file or directory
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 00:48
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
