-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   tar error on OpenFOAM2.0.1 (http://www.cfd-online.com/Forums/openfoam-installation/92109-tar-error-openfoam2-0-1-a.html)
strikeraj September 2, 2011 10:16
Hi
When i tried to tar -xvzf OpenFOAM-2.0.1.gtgz i am getting this error
OpenFOAM-2.0.1/tutorials/multiphase/interPhaseChangeFoam/cavitatingBullet/constant/triSurface/bullet.stl
tar: Skipping to next header
tar: Archive contains obsolescent base-64 headers
gzip: stdin: invalid compressed data--crc error
gzip: stdin: invalid compressed data--length error
tar: Child returned status 1
tar: Error exit delayed from previous errors
Anyone knows if there is any solution or an alternate way to unpack the source?
Thanks a lot
Cheers
Tom
wyldckat September 2, 2011 13:29
Greetings Tom,
Probably there was an error during the download process. See in the page http://www.openfoam.com/download/source.php the md5sum numbers for each tarball package. To check each package, simply run:
md5sum  OpenFOAM-2.0.1.gtgz
md5sum  ThirdParty-2.0.1.gtgz
The outputted hexadecimal numbers should be identical to the ones on the web page above!
edit: I forgot to mention that if they aren't identical, then you will need to download them once again!
Best regards,
Bruno
strikeraj September 2, 2011 14:18
Originally Posted by wyldckat (Post 322685)
Greetings Tom,
Best regards,
Bruno
Hi Bruno
Thank you for your reply. You are right the md5sum is different. I am going to download and check again.
Cheers,
Tom
