September 27, 2011, 10:19 |
paraview 3.10.1 compiling error (1.6-ext)
Vesselin Krastev
Rep Power: 20 |
Hi everyone,
has anybody succeeded in solving the following compiling error (it comes at the end of the Allmake script run into the ThirdParty directory of OpenFOAM-1.6-EXT)? CMake Error at /home/chuang/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.10.1/CMake/BundleUtilities.cmake:627 (message): error: fixup_bundle: not a valid bundle Call Stack (most recent call first): Applications/ParaView/cmake_install.cmake:80 (fixup_bundle) Applications/cmake_install.cmake:37 (INCLUDE) cmake_install.cmake:118 (INCLUDE) Searching in the web I've found this post: http://comments.gmane.org/gmane.comp...iew.user/11668 I've tried to turn off this option (it's in the /rpmBuild/BUILD/ParaView-3.10.1/CMake/ParaViewCommon.cmake file), but it seems like it is again turned on by some kind of default setting, because after turned it off the compilation stops again at the same point and opening back the ParaViewCommon.cmake file it appears again as the default version... Any help will be appreciated V. PS-Has anybody succeeded AT ALL in compiling paraview 3.10.1 inside the 1.6-ext release????? |
September 28, 2011, 07:15 |
Vesselin Krastev
Rep Power: 20 |
Do I have to understand that all the 1.6-ext users do not use the ThirdParty-compiled paraview 3.10.1 for postprocessing?
V. |
September 29, 2011, 05:07 |
looks like most of the users dealing with Extend-Version go to "extend-project" http://www.extend-project.de/user-fo...n-openfoam#286 |
September 29, 2011, 05:45 |
#4 | |
Vesselin Krastev
Rep Power: 20 |
Regards V. |
September 30, 2011, 11:42 |
Jason Eason
I had the same problem, I switched to paraview-3.8.1 and now paraview works. Find your paraview.spec file its in the ThirdParty/rpmBuild/SPECS folder. Rename the file to Paraview-3.8.1, and also change all the 3.10.1 to 3.8.1 inside the file. This should work, I had to adjust and few things afterward, but they were not a big deal. Any further problem post here all I will see if I can help.
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0 |
September 30, 2011, 11:48 |
#6 | |
Vesselin Krastev
Rep Power: 20 |
V. |
October 10, 2011, 05:01 |
#7 | |
Vesselin Krastev
Rep Power: 20 |
V. |
October 28, 2011, 03:17 |
fixed bundle problem solution
P.A.
I managed to fix the problem with the fixup_bundle issue following another post (I can't remember the link). So: In the ParaView3.10.1 SPECS file (in ThirdParty/rpmbuild/SPECS) I added/altered some lines after ... echo " _mesaLibPath : %{_mesaLibPath}" echo " _pythonLibPath : %{_pythonLibPath}" echo "" set -x # For Python and MPI Support (by the way, you need this to be added explicitly to # compile PYTHON shell and parallel support into ParaView. The entries earlier in this file # are not sufficient in my case) addCMakeVariable PARAVIEW_ENABLE_PYTHON:BOOL=ON addCMakeVariable PARAVIEW_USE_MPI:BOOL=ON # >>> Here comes the fixup_bundle solution addCMakeVariable PARAVIEW_INSTALL_THIRD_PARTY_LIBRARIES:BOOL=OFF # start with these general settings addCMakeVariable VTK_USE_TK:BOOL=OFF # >>> I think one this is necessary too. addCMakeVariable BUILD_SHARED_LIBS:BOOL=OFF VTK_USE_RPATH:BOOL=OFF #addCMakeVariable BUILD_SHARED_LIBS:BOOL=ON VTK_USE_RPATH:BOOL=OFF addCMakeVariable CMAKE_BUILD_TYPE:STRING=Release # >>> And in case you have some trouble with MESA related errors you can comment Hrvoje's additional # lines, like this: # HJ, 9/Aug/2011 #addCMakeVariable OPENGL_gl_LIBRARY:STRING= # HJ, 9/Aug/2011 #addCMakeVariable VTK_USE_OPENGL_LIBRARY:BOOL=ON At least this is the way I finally got OF-1.6-ext with ParaView3.10.1 running on a CentOS 5.3 (Kernel 2.6.18-128.4.1.el5) machine. Hope that helps! Cheers, Pascal. |
[OpenFOAM] Segmentation fault with paraview 3.10.1 | aot | ParaView | 5 | June 5, 2023 01:32 |
error install Paraview 3.10.1 qt | preibie | OpenFOAM | 6 | August 24, 2011 16:11 |
OF-1.6-ext enable MPI in paraview compiling | pcaron | OpenFOAM Installation | 2 | March 7, 2011 17:58 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 07:11 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
