Home > Forums > OpenFOAM Installation
swak4Foam installation on 2.0
Like Tree1Likes
Old   August 14, 2013, 11:15
Raymond.Leoi is on a distinguished road
Exactly as you said. I killed it since I thought it's dead.
Should I worry about the first issue that some files can't be opened?
Originally Posted by gschaider View Post
With "stopped at" at you mean "I saw this output and nothing seemed to happen so I stopped it with Ctrl-C", right? That is EXACTLY the situation "If compilation of the grammers ..." is talking about: bison generates from the grammar file a C++-code that is thousands of lines long. The compiler will try to optimize this and this may take very long on some machines/compilers. And sometimes the compiler may run out of memory. As the real compuations are taking place elsewhere for these files it is sufficient if they are compiled only with the most basic optimizations. The compile script allows to override this with
export SWAK_COMPILE_GRAMMAR_OPTION=-O1
<rant>I really sometimes wonder why I try to make the compile-scripts stable if people don't bother to read the output anyway. And no: putting the whole explanation into the script output will probably make situations worse because the young people nowadays don't read documentations/error messages that are more than two lines long and don't have pictures. In the good old days ..... </rant>
Raymond.Leoi is offline   Reply With Quote
Old   August 14, 2013, 18:14
Assistant Moderator
Bernhard Gschaider
No. That is not a problem
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Thread Tools
Trackbacks are On
OpenFoam 2.0.0 installation Jan_Peters OpenFOAM Installation 86 April 27, 2012 05:32
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Installation problems indy OpenFOAM Installation 7 April 3, 2009 09:40
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 13:29
