installation with Intel MPI and Intel compilers
After running with the standard gcc and open-mpi configuration I'd like to install and test with Intel's compilers and MPI.
Allwmake tells me: .../OpenFOAM/OpenFOAM-1.7.1/lib/linux64IccDPOpt/libscotch.so: undefined reference to `pthread_detach' Where should this pthread_detach come from? Changes to etc/bashrc: # Compiler: set to Gcc, Gcc43, Gcc44, or Icc (for Intel's icc) : ${WM_COMPILER:=Icc}; export WM_COMPILER and added later in the file appropriate compiler options for the Intel compilers etc/settings.sh: INTELMPI) mpi_version=intelmpi-3.2.2.006 export MPI_ARCH_PATH=$I_MPI_ROOT # echo $I_MPI_ROOT # /opt/intel/impi/3.2.2.006 # Tell OpenMPI where to find its install directory # export OPAL_PREFIX=$MPI_ARCH_PATH # _foamAddPath $MPI_ARCH_PATH/bin _foamAddPath $MPI_ARCH_PATH/bin64 # _foamAddLib $MPI_ARCH_PATH/lib _foamAddLib $MPI_ARCH_PATH/lib64 _foamAddMan $MPI_ARCH_PATH/man export FOAM_MPI_LIBBIN=$FOAM_LIBBIN/$mpi_version unset mpi_version ;; Regards Achim |
Greetings Achim,
I haven't tried building OpenFOAM 1.7.1 with Icc, but I can tell you that in OpenFOAM 2.0.x the Scotch libraries are built with Gcc, precisely due to those issues you are getting. You can see this particular fix in action here: https://github.com/OpenFOAM/ThirdPar.../Allwmake#L221 - it starts in line 221. Best regards, Bruno |
so I switched to 2.0.1, but still ran into some error: + decompose/Allwmake + wmakeLnInclude decompositionMethods + '[' -n /work/appl/OpenFOAM/ThirdParty-2.0.1/platforms/linux64Icc/scotch_5.1.11 ']' + wmake libso scotchDecomp Making dependency list for source file scotchDecomp.C + '[' -d /work/appl/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64IccDPOpt/lib/ ']' + wmakeMpiLib ptscotchDecomp + set +x ptscotchDecomp.C(126): catastrophic error: cannot open source file "ptscotch.h" #include "ptscotch.h" ^ compilation aborted for ptscotchDecomp.C (code 4) make: *** [Make/linux64IccDPOptINTELMPI/ptscotchDecomp.o] Error 4 So it seems something in my setup is still wrong ... Any idea? Regards Achim |
Hi Achim,
OK, let's do some isolate-and-conquer by only building the ThirdParty folder first:
Bruno |
1 Attachment(s)
Hi Bruno, here we go (I have split out and error into 2 files, hope that's OK). Best regards Achim |
Hi Achim,
I wanted the output and error messages to be in the same file, so I could have an historic detailing of where/when the errors occurred. This way I have separate history lines... Either way, my suspicion is that you edited the following code in "etc/config/settings.sh": Code:
x86_64) By the way, knowing which Gcc version and Linux architecture would make it easier for me to help you. To know the architecture, run: Code:
uname -m Bruno |
Installation
1 Attachment(s)
Hi Bruno,
here it comes: # cat /etc/SuSE-release SUSE Linux Enterprise Server 11 (x86_64) VERSION = 11 PATCHLEVEL = 1 # uname -m x86_64 # uname -a Linux machine 2.6.32.12-0.7-default #1 SMP 2010-05-20 11:14:20 +0200 x86_64 x86_64 x86_64 GNU/Linux # gcc -v Using built-in specs. Target: x86_64-suse-linux Configured with: ../configure --prefix=/usr --infodir=/usr/share/info --mandir=/usr/share/man --libdir=/usr/lib64 --libexecdir=/usr/lib64 --enable-languages=c,c++,objc,fortran,obj-c++,java,ada --enable-checking=release --with-gxx-include-dir=/usr/include/c++/4.3 --enable-ssp --disable-libssp --with-bugurl=http://bugs.opensuse.org/ --with-pkgversion='SUSE Linux' --disable-libgcj --disable-libmudflap --with-slibdir=/lib64 --with-system-zlib --enable-__cxa_atexit --enable-libstdcxx-allocator=new --disable-libstdcxx-pch --enable-version-specific-runtime-libs --program-suffix=-4.3 --enable-linux-futex --without-system-libunwind --with-cpu=generic --build=x86_64-suse-linux Thread model: posix gcc version 4.3.4 [gcc-4_3-branch revision 152973] (SUSE Linux) Best regards Achim |
Hi Achim,
Could you please run the command with the "2>&1" in the end!? Code:
./Allwmake > make.log 2>&1 Code:
./Allwmake 1>> make2in1.log 2>> make2in1.log Because there seems to have been problems building ptscotch, but those errors aren't in the file you posted! Best regards, Bruno |
installation
1 Attachment(s)
Dear Bruno,
I ran as you proposed. So for the ThirdParty stuff it seems to be OK ... Just to be sure, here it is again (, ThirdParty stuff only, after Allclean): ./Allwmake > make.log 2>&1 Best regards Achim |
Then something strange is going on... there is no indication that "ptscotch" built at all :( You'll probably run into the same problem as before.
I checked the settings during excution of ThirdParty.../Allwmake and
found 2 strange things: #1 SCOTCH_ARCH_PATH in Allwmake is OpenFOAM/ThirdParty-2.0.1/platforms/linux64Gcc/scotch_5.1.11 though normally I'm doing OPT and DP, i.e. I would have expected this to be OpenFOAM/ThirdParty-2.0.1/platforms/linux64GccDPOpt This seems wrong to me, right? #2 FOAM_MPI is not set, so I don't get into the make of ptscotch. This of course explains why I get the errors. With the standard OpenMPI config I get libptscotch.so in OpenFOAM/ThirdParty-2.0.1/platforms/linux64GccDPopt/lib/ openmpi-1.5.3 (this is from my notices, hope I wrote it down right ;-)) Regards Achim |
Hi Achim,
Right now I can't spend any time looking into this in detail, so all I can say is what I've already written ;) Best regards, Bruno |
Hi Bruno, in the meantime I got further: I could link a complete executable and start it, but so far it error exited. (I have another urgent activity, so it may take some time until I can spend cycles on it, but I will keep you updated.) Many thanks for all your help, Bruno! Bets regards Achim |
