-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   OpenFOAM 1.6-ext git installation (http://www.cfd-online.com/Forums/openfoam-installation/94065-openfoam-1-6-ext-git-installation.html)
Attesz November 4, 2011 04:54
Hi Foamers,
I'm following this manual: http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/OpenFOAMonYourOwnLaptop.html
but at the following commands I got errors:
attila@ubuntu:~/OpenFOAM/OpenFOAM-1.6-ext$ git merge remotes/origin/hotfix/ThirdParty_scripts
Auto-merging etc/settings.csh
CONFLICT (content): Merge conflict in etc/settings.csh
Auto-merging etc/settings.sh
Automatic merge failed; fix conflicts and then commit the result.
fatal: 'merge' is not possible because you have unmerged files.
Please, fix them up in the work tree, and then use 'git add/rm <file>' as
appropriate to mark resolution and make a commit, or use 'git commit -a'.
Do you know what's the problem? Where can I find a description about git install of 1.6-ext for dummies? :)
Thank you,
Attila
elvis November 4, 2011 12:53
i had a similar problem with "settings.sh" i think i just "renamed or removed" that file
and went back to ~/OpenFOAM/OpenFOAM-1.6-ext
and made a
git pull
http://www.extend-project.de/user-fo...ation-openfoam might be a useful thread
Attesz November 5, 2011 11:56
I renamed that file as you suggested but it doesn't work...
Thanks,
Attila
zhaowei November 10, 2011 07:58
just ignore this message. try it
