Error Compiling OpenFOAM-2.0.1 on Ubuntu 10.04 |
December 5, 2011, 16:52 |
Sebastian P
Rep Power: 15 |
Hello everybody,
since I was not satisfied with the result of the automatic ubuntu installation of openfoam, I now tried to manually install it. But the following Problem occurs: I copied the folders "OpenFOAM-2.0.1" and "ThirdParty-2.0.1" to "/home/sebastian/OpenFOAM/" and when i run Allmake in the OpenFOAM-folder without sudo, I get many many errors. But when i execute "sudo ./Allwmake", I get the message "/Allwmake: 10: wmakeCheckPwd: not found Error: Current directory is not $WM_PROJECT_DIR The environment variables are inconsistent with the installation. Check the OpenFOAM entries in your dot-files and source them." Does anybody know how to solve this problem? Regards, Sebastian |
December 6, 2011, 07:24 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Sebastian,
Bruno
December 6, 2011, 18:04 |
Sebastian P
Rep Power: 15 |
Hello Bruno,
thanks alot, I now managed to compile everything. My mistake was that I did not set chmod correctly for the extracted installation files, I found out when I couldn't create the logfile you proposed. Also the 4 processor hint was very nice Thanks alot again! Best regards, Sebastian |
Display Modes | |
OpenFoam 1.7.1 in Ubuntu 10.04 won't start working | Leech | OpenFOAM Installation | 8 | August 10, 2014 20:42 |
OpenFOAM 1.7 Ubuntu 10.04 | stark22 | OpenFOAM Installation | 2 | July 24, 2011 11:22 |
OpenFOAM Installation Errors on Ubuntu 10.04 | ozzythewise | OpenFOAM Installation | 1 | June 19, 2010 05:59 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 14:43 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
