Error Compiling OpenFOAM-2.0.1 on Ubuntu 10.04
Old   December 5, 2011, 16:52
Default Error Compiling OpenFOAM-2.0.1 on Ubuntu 10.04
Sebastian P
SePe is on a distinguished road
Hello everybody,
since I was not satisfied with the result of the automatic ubuntu installation of openfoam, I now tried to manually install it.
But the following Problem occurs: I copied the folders "OpenFOAM-2.0.1" and "ThirdParty-2.0.1" to "/home/sebastian/OpenFOAM/" and when i run Allmake in the OpenFOAM-folder without sudo, I get many many errors. But when i execute "sudo ./Allwmake", I get the message
"/Allwmake: 10: wmakeCheckPwd: not found
Error: Current directory is not $WM_PROJECT_DIR
The environment variables are inconsistent with the installation.
Check the OpenFOAM entries in your dot-files and source them."
Does anybody know how to solve this problem?
Regards,
Sebastian
SePe is offline   Reply With Quote
Old   December 6, 2011, 07:24
Retired Super Moderator
Bruno Santos
Greetings Sebastian,
  1. Do not use sudo to build OpenFOAM in your own home folder.
  2. Follow the official instructions to the letter: http://www.openfoam.com/download/source.php
  3. Before running Allwmake, run this:
    export WM_NCOMPPROCS=4
    Where 4 is the number of cores in your machine. This way it'll be faster building OpenFOAM.
  4. When you run Allwmake, run it like this instead:
    ./Allwmake > make.log 2>&1
    This way you'll keep a good log in "make.log" of every step taken by OpenFOAM's build process.
Good luck!
Bruno
Old   December 6, 2011, 18:04
Sebastian P
Hello Bruno,
thanks alot, I now managed to compile everything. My mistake was that I did not set chmod correctly for the extracted installation files, I found out when I couldn't create the logfile you proposed.
Also the 4 processor hint was very nice
Thanks alot again!
Best regards,
Sebastian
OpenFoam 1.7.1 in Ubuntu 10.04 won't start working Leech OpenFOAM Installation 8 August 10, 2014 20:42
OpenFOAM 1.7 Ubuntu 10.04 stark22 OpenFOAM Installation 2 July 24, 2011 11:22
OpenFOAM Installation Errors on Ubuntu 10.04 ozzythewise OpenFOAM Installation 1 June 19, 2010 05:59
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
