December 14, 2011, 09:58 |
Error gcc compiler
Goutam Saha
Rep Power: 14 |
Error:
Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/thermo/gsaha/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/thermo/gsaha/OpenFOAM/gsaha-2.0.1 no no $WM_THIRD_PARTY_DIR ...ermo/gsaha/OpenFOAM/ThirdParty-2.0.1 yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR ...thermo/gsaha/OpenFOAM/OpenFOAM-2.0.1 yes yes yes $FOAM_APPBIN ....0.1/platforms/linux64Gcc44SPOpt/bin yes yes yes $FOAM_SITE_APPBIN ....0.1/platforms/linux64Gcc44SPOpt/bin no no $FOAM_USER_APPBIN ....0.1/platforms/linux64Gcc44SPOpt/bin no no $WM_DIR .../gsaha/OpenFOAM/OpenFOAM-2.0.1/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ....0.1/platforms/linux64Gcc44SPOpt/lib yes yes yes $FOAM_SITE_LIBBIN ....0.1/platforms/linux64Gcc44SPOpt/lib no no $FOAM_USER_LIBBIN ....0.1/platforms/linux64Gcc44SPOpt/lib no no $MPI_ARCH_PATH ...platforms/linux64Gcc44/openmpi-1.5.3 yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- flex /usr/bin/flex ERROR: gcc version is too old for this release of OpenFOAM User version : 4.1.2 Minimum required: 4.3.2 "I have installed gcc 4.4.4 in Centos 5 Linux". How I will solve this problem? |
December 15, 2011, 16:48 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Answered here: http://www.cfd-online.com/Forums/ope...tml#post336010
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Fortran compiler | Erik | Siemens | 2 | November 28, 2008 20:05 |
Intel compiler for linux x86 | marcus | Siemens | 1 | November 9, 2006 16:43 |
Fluent 6.2 and gcc compiler in Sun Blade 2500 | Nitu Gupta | FLUENT | 8 | April 29, 2005 13:58 |
Fortran compiler | Arnab | Siemens | 5 | September 14, 2004 03:59 |
