OpenFoam 2.1.0 Ubuntu release 19/12/2011
Hello everyone,
I'm trying to install OpenFOAM 2.1.0 on Ubuntu 11.10. I have no experience about linux and openFoam, I'm just moving my first steps in numerical simulation field. Following installation instructions from http://www.openfoam.org/download/ubuntu.php, I got this error at step 3... when I type -> sudo apt-get install openfoam210: Err http://www.openfoam.com/download/ubuntu/ oneiric/main openfoam210 i386 0-1 404 Not Found Impossibile recuperare http://www.openfoam.com/download/ubu...0_0-1_i386.deb 404 Not Found Suggestions? |
maybe you didnt wrote
VERS=`lsb_release -cs` in terminal prompt. i installed today. there was no problem.. |
First time I didn't... but then I tried again the procedure from beginning using VERS=`lsb_release -cs` and it doesn't work. |
I have the same version 11.10 and it does not work for me either.
I followed the instructions on the official openfoam homepage. While trying to install ParaView the same error occurs when 1 file is not found... Any ideas? |
Greetings to all!
Just to close the loop, thanks to Ancioi's report on the bug tracker - http://www.openfoam.com/mantisbt/view.php?id=372 - this problem has already been fixed. Best regards, Bruno |
