[OpenFOAM.org] paraview compilation error paraview-3.12.0
Like Tree4Likes
Old   December 26, 2011, 08:02
Default paraview compilation error paraview-3.12.0
Balkrishna Patankar
balkrishna is on a distinguished road
Hi ,
On running makeParaView in the Third Party folder i get the following error :
make: *** No targets specified and no makefile found.  Stop.
Command exited with non-zero status 2
0.00user 0.00system 0:00.00elapsed 200%CPU (0avgtext+0avgdata 4048maxresident)k
0inputs+0outputs (0major+305minor)pagefaults 0swaps
The OpenFOAM installation proceeds without any problems. Does anyone have a clue to this ?
Thanks.
balkrishna is offline   Reply With Quote
Old   December 26, 2011, 09:47
Retired Super Moderator
Bruno Santos
Greetings Balkrishna,
OK... since my crystal ball is broken, so I'll have to ask:
  1. Which Operating System are you using? Or better yet, which Linux distribution/version are you using?
  2. Which OpenFOAM version are you trying to install?
  3. That is only the very final lines of the build output. Please provide the complete log by following these steps:
    1. Run it like this:
      ./makeParaView > makePV.log 2>&1
    2. Edit the log file "makePV.log" and replace any sensitive data, such as user names and paths.
    3. Package the log:
      tar -czf makePV.log.tar.gz makePV.log
    4. Attach "makePV.log.tar.gz" on your next post.
Best regards,
Bruno
Old   December 27, 2011, 02:17
Balkrishna Patankar
Thanks for the prompt reply. I shd have included the details in the previous post. Anyways the details are as follows :
i) OS : Ubuntu 10.04 32 bit
ii) OpenFOAM version : 2.1.0 - source pack
The file is attached with this post.
Thanks,
Balkrishna.
Old   December 27, 2011, 06:17
Bruno Santos
Hi Balkrishna,
Mmm, this is odd... the specific error is this:
CMake Error at CMakeLists.txt:70 (determine_version):
  determine_version Function invoked with incorrect arguments for function
  named: determine_version
I've tested in a virtual machine with Ubuntu 10.04 i686 and I didn't get this error. Which cmake version are you using?
cmake --version
Additionally, which version does Ubuntu say it's installed?
dpkg-query -W cmake
I've got this version:
cmake version 2.8.0
cmake    2.8.0-5ubuntu1
Best regards,
Bruno
Old   December 27, 2011, 06:28
Balkrishna Patankar
I have got this version :
cmake version 2.8.0
It seems there is no difference in the cmake versions.
Balkrishna.
Old   December 27, 2011, 06:32
Bruno Santos
Mmm... then I recommend that you erase the "ParaView-3.12.0" folder from "ThirdParty-2.1.0" and replace it with the official version available from here: http://www.paraview.org/files/v3.12/ - namely: http://www.paraview.org/files/v3.12/...-3.12.0.tar.gz
There shouldn't be any big differences between them, but sometimes downloading and unpacking packages fails in some point during the download or unpacking process, so it's either necessary to download the package again or unpack it again.
Old   December 27, 2011, 06:35
Balkrishna Patankar
Will try it out and post results here ...
Thanks for the help.
Old   December 27, 2011, 06:54
Balkrishna Patankar
The same error again. Attaching the log file with this mail.
Balkrishna.
Old   December 27, 2011, 08:48
Bruno Santos
OK, then lets try building a custom CMake with a more recent version:
  1. Go into the ThirdParty folder, get a script for downloading the CMake source code and make it executable:
    foam3rdParty
    wget "http://www.openfoam.com/mantisbt/file_download.php?file_id=143&type=bug" -O getCmake
    chmod +x get*
  2. Build CMake:
    ./getCmake
    ./makeCmake > mkcmake.log 2>&1
  3. Update the shell environment:
    wmSET
  4. Confirm that you now have a different and more up-to-date version:
    cmake --version
  5. Try to build ParaView once again:
Hopefully this will fix the problem!
Good luck!
Bruno
linch, maysmech, Ivooo and 1 others like this.
Last edited by wyldckat; January 4, 2012 at 16:04. Reason: there was a missing line break on point #2
Old   December 28, 2011, 08:42
Smile Thanks
continua is on a distinguished road
I work with balkrishna, and thank you for your help in this.
continua is offline   Reply With Quote
Old   December 28, 2011, 15:03
Bruno Santos
You're both welcome! I'm glad I could help.
Best regards,
Bruno
Old   January 3, 2012, 00:56
Default Paraview and paraFoam not working
  #12
sandip
vmsandip2011 is on a distinguished road
i am tring to install the OpenFOAM-2.1.0 on Ubuntu10.04 using Virtual Box.
OpenFOAM-2.1.0 is installed properly but I am having problem in running Paraview and ParaFOAM.
I tried to follow the steps in this link http://www.openfoam.org/download/source.php .
But if I ran the command ./makeParaView paraview is not getting installed .
I tried to follow the above link written by wyldckatdownloading new Paraview , but the messgae log is ame .
I have attached here with makePV.log.
Please let me know the problem.
vmsandip2011 is offline   Reply With Quote
Old   January 3, 2012, 03:57
Bruno Santos
Greetings Sandip and welcome to the forum!
Did you follow the steps indicated in post #9?
Best regards,
Bruno
Old   January 3, 2012, 05:54
  #14
sandip
Thanks for quick reply.
i tried to follow the steps in #9 but still the log generated is same as attached in previous post.
Following message is getting created:
0.00user 0.00system 0:00.00elapsed 133%CPU (0avgtext+0avgdata 4064maxresident)k
0inputs+0outputs (0major+308minor)pagefaults 0swaps
Done make
Installing ParaView to /home/user/OpenFOAM/ThirdParty-2.1.0/platforms/linuxGcc/paraview-3.12.0
make: *** No rule to make target `install'. Stop.
Installation complete for paraview-3.12.0
Set environment variables:
export ParaView_DIR=/home/ravindra/OpenFOAM/ThirdParty-2.1.0/platforms/linuxGcc/paraview-3.12.0
export PATH=$ParaView_DIR/bin:$PATH
export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.12
Done
Old   January 4, 2012, 02:38
Smile OF documentation
  #15
hust
kebi112358 is on a distinguished road
I'm just starting to learn OpenFOAM, but I can't find enough documentations.Could anybody help to pass the relevant resources to me?
kebi112358 is offline   Reply With Quote
Old   January 4, 2012, 16:17
Bruno Santos
Greetings!
@Sandip:
I've finally managed to reproduce the same problem you guys were and are having! I had to install Ubuntu 10.04 i686 on VirtualBox to achieve the same bug! I was using VMPlayer... not sure why that would make such a difference.
Anyway, after following my own suggestions/instructions, I noticed that on post #9 I forgot a line break on point #2! So, please follow once again the updated instructions from post #9!
@kebi112358:
Go to the link on my signature and start following the links starting from the line: "Finally, a few links for starting to use OpenFOAM".
Best regards,
Bruno
Old   January 5, 2012, 08:11
  #17
sandip
Thanks for the reply with your changes in #9 everything working fine for OpenFoam2.1.0
But if you follow the steps given at this link :
OpenFoam2.0 is getting installed properly but not 2.1.0 version.
Anyway thanks for the information.
with regards,
sandip
Old   January 5, 2012, 16:11
Bruno Santos
Hi Sandip,
According to your description, my guess is that you have at least two OpenFOAM installations. If this is the case, then edit your "$HOME/.bashrc" file and change the following lines (this is an example):
source $HOME/OpenFOAM/OpenFOAM-2.0.0/etc/bashrc
source $HOME/OpenFOAM/OpenFOAM-2.1.0/etc/bashrc
To this:
alias of200='source $HOME/OpenFOAM/OpenFOAM-2.0.0/etc/bashrc'
alias of210='source $HOME/OpenFOAM/OpenFOAM-2.1.0/etc/bashrc'
Start a new terminal window/tab and run the respective alias command. For example, to have OpenFOAM 2.0.0 active in the terminal window/tab you've just opened, run:
of200
Does this solve your problem? If not, I'll need a bit more information... otherwise I'll just be trying to guess what the problem might be
Best regards,
Bruno
Old   January 6, 2012, 11:12
  #19
sandip
Hi ,
Thanks for the reply.
I am not saying 2.1.0 is not getting installed.
With your update to #9 , 2.1.0 is getting installed properly.
But with the steps written at link http://www.openfoam.org/download/source.php ,
OpenFoam 2.0.0 is getting installed properly , but paraview/paraFoam for 2.1.0 is not getting installed , this was just information i was sharing for somebody whoever is going to follow the steps at above link.
with regards.
Old   January 6, 2012, 12:47
Bruno Santos
Hi Sandip,
Thanks for clearing that up! Indeed, Ubuntu 10.04 is already becoming outdated, when it comes to modern software such as ParaView 3.12.0.
To complement your posts, the older instructions are available here: http://www.openfoam.org/download/archive.php
Best regards,
Bruno
installation, paraview 3.12
Error building ParaVIEW 3.12.0 in CentOS 6.5 wjm OpenFOAM Installation 8 February 17, 2014 10:17
Compiling ParaView 3.12.0 on SUSE Linux Enterprise bmikuz OpenFOAM Installation 1 November 9, 2012 18:55
Installation Problem with ParaView 3.12.0 on Scientific Linux 5.7 Wley OpenFOAM Installation 2 September 28, 2012 06:06
[OpenFOAM] [Critical] ParaView 3.12.0 breaks monitor signal in Ubuntu 11.04 v_mil ParaView 5 March 18, 2012 13:39
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
